Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 10-28-2005, 09:34 AM   #1 (permalink)
Photos: 0
Hot Sauce is an unknown quantity at this point
yellow engine oil mark...
when i shut the engine off it shows the yellow check engine oil mark..
i read the manuel and says that i need to add oil or something.. if that's the case? what kind of oil does it need.. is this something that happens often? i mean i only drove the car about 7000 miles and have 6500 miles before services.... i drive a 05 330xi....
Thanx in advance guys..
Hot Sauce is offline   Reply With Quote
Old 10-28-2005, 11:48 AM   #2 (permalink)
storme's Avatar
Photos: 0
storme is an unknown quantity at this point
in the uk we can use...
castrol slII long life......
or just goto the dealership...the oil isnt that expensive from there
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 10-30-2005, 02:44 PM   #3 (permalink)
Photos: 0
It sounds like you left the lights on and the battery went flat by leaving overnight it built up enough charge to start the car. When it was cranking the battery voltage went low enough to store a voltage fault and put the trans light on now you’re using the car it has charged the battery so no more warning lights the oil useage will settel down with use
Old 10-31-2005, 09:33 AM   #4 (permalink)
Photos: 0
i added oil that i bought from the dealership and everything seems fine.. so far... thank you all..
Old 11-02-2005, 01:08 PM   #5 (permalink)
Photos: 0
yellow is low level, red is low pressure. i think this is in u.s. cars though. not sure about euro, canada.
they can use a quart every 5-8 k. if that is it, and not increasing, i'd leave it alone...
vB code is On
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-11-2006 12:56 AM
what engine oil to put in because i dont know if its syntec or normal? träumer 3-Series (E21, E30) 3 11-01-2005 03:40 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 10:25 PM
BMW P83 Engine triggrhaapi Bimmer Talk/Motorsports Talk 0 07-21-2003 03:03 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
