wrong bleeding procedure or blown head gasket? - BMW Forum - BimmerWerkz.com
Old 03-19-2011, 08:50 PM   #1 (permalink)
Car: 1994 325Ci (Cabriolet)
bavareze is on a distinguished road
Send a message via Yahoo to bavareze Send a message via Skype™ to bavareze
Hello,
I am having a problem with my 323i with 170k.
One week ago it overheated badly. Someone else was driving I noticed the expansion tank was punctured and coolant leaked.
So I got a new tank. After that I filled with coolant. I opened the bleeding screw while filling to make sure air goes out. Then when I start the car I see some issues:
- immediately a lot of pressure builds in the hoses.
- coolant does not circulate through the hoses
so I went to get a new thermostat, put it in, redid bleeding.
same issues: as soon as I start the car there will be a lot of pressure in the cooling system.
shall I go ahead and assume head gasket is gone?
Thanks!
bavareze is offline   Reply With Quote
Old 03-19-2011, 11:59 PM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
If you leave the cap off the expansion tank does the system still build up pressure?
Try running the car without a thermostat installed at all, maybe there is an air lock stopping it from working.
Check that the hose that runs from the radiator to the bleeding screw and expansion tank isn't kinked, apparently that can stop air from being purged.
Riding in style
Old 03-20-2011, 12:06 AM   #3 (permalink)
even without thermostat (which, btw, comes with the housing so it's not possible to remove on E46) the car shouldn't build pressure in 10 seconds after starting. should only build pressure after water is boiling inside.
The hose from radiator to bleeding screw is 4 cm thick, not blocked at all.
blown head gasket blown325i New Members Check In 4 07-18-2008 11:43 AM
Blown head gasket, Cracked cylinder head... Blackoutmp M-Series (M1, M3, M5, M6) 8 04-04-2006 01:51 AM
Help Does A Blown Head Gasket/head Make Noise? E36k224 3-Series (E36) 7 03-17-2005 12:18 PM
Blown head gasket, new motor or new gasket? Bmw528i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:06 AM
Blown Head Gasket TT535 5-Series (E12,E28, E34, E39, E60) 7 12-06-2003 08:01 AM
