Wiring Gremlins! - BMW Forum - BimmerWerkz.com
Old 07-23-2008, 08:46 PM   #1 (permalink)
Car: 01 330Ci
rock.krawler@comcast.net is on a distinguished road
Send a message via Yahoo to rock.krawler@comcast.net
Wiring Gremlins!
I bought an 01 330ci 3 weeks ago, got what I figured was a smokin deal. There were issues that I figured would be an easy fix. I am starting to think otherwise. I will list what I am looking at, and if someone can help it would be very much appreciated.
Horn does not work. checked fuses, pulled horns and try hot wires, they still do not work, I am thinking buy new ones.
Washer fluid pump does not work. have not checked it out yet.
Emergency flashers do not work( dealer seems to think someone spilled something on console because door lock does not work either).
I also have 2 small wires hanging on the passenger side by the horn, colors are green with black tracer, and green with yellow tracer.
The previous owner apparently pulled up on a curb, then when they backed off, it tore stuff out. The front inner fender liners are missing, along with the outside temp sensor( which I replaced and is now working), one fog lamp, the air ducts for the brakes are broken also. Is there a possibility that there is a major wire that has been unplugged or torn someplace that I am not able to see?
Thanks for any help!!
John
rock.krawler@comcast.net is offline   Reply With Quote
Old 07-23-2008, 09:34 PM   #2 (permalink)
addtothehustle is on a distinguished road
hope this helps
As far the horns, your probably right, you need new ones, if you can't find any other problems. The horns are probably blown.
Second with the fluid pump, check to see if you can here the pump working, if you do, then pump is fine and your hoses leading to the squirters are clogged.
If all else is clear and the no pump noise, then you most likely need a new pump.
The last two, i couldn't help you, but for everything, i would find a reputable technician and have them take a look. As far as the locks and flashers go, it might be a cheap part however just labor intensive. But any mechanic would give you a quote that you can approve before they do the work.
-addtothehustle
www.ineedaradiator.com
addtothehustle is offline   Reply With Quote
Old 07-23-2008, 11:21 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Talking
What you gripin' about???...
darn* sounds pretty minor to me! horns are easy... dangling wires should give you the clue. as in, test for voltage from the dangling wires when a buddy presses the horn button. voltage, yes, then the horns went bad, voltage no, then retrace your lines to the horn switch. ditto the washer...
emergency flashers do not work.. how about the left and right turn signals? yes?... then, your prob is the hazard/emergency switch... if no, then the prob is in most cases a faulty relay.
inner fender liners... REPLACE them, they're available :-)
what else dsnt work... ?
Headlight Gremlins Bear 3-Series (E21, E30) 7 03-09-2007 02:39 PM
X5 Electrical Gremlins Year 2001 bradvo 1,6,7,8 - Series and Mini Cooper 3 12-21-2004 09:11 PM
Gremlins in my Baby! marinersfan 3-Series (E21, E30) 0 04-22-2004 08:31 AM
My Car's Gremlins Strike again... Maz 5-Series (E12,E28, E34, E39, E60) 12 03-12-2004 02:31 AM
New car gremlins strike again nosuchsol 5-Series (E12,E28, E34, E39, E60) 4 02-24-2004 03:39 AM
