| Fuse box is in the Glove Compartment
1 Open the glove compartment and
turn the two white quick-release
fasteners outward. Spare fuses and
plastic tweezers are located on the
fuse holder
2 Use the plastic tweezers to remove
the fuse for the accessory or equipment
that has stopped working
3 If the fuse is burned through (the
metal strip is melted and separated),
replace it with a new fuse of the same
ampere rating (color code).
There should be a card or a sticker stuck to the upper side telling you what eah fuse is for.
__________________ VELVET BLUE UK INDIVIDUAL , IM THE LAST  UNITED WE STAND DIVIDED WE FALL
I stepped in a plate of Pasta the other day - now I have to worry about my Carbonara footprint! |
