winter tires different front/back width - BMW Forum - BimmerWerkz.com
Old 12-24-2007, 01:08 AM   #1 (permalink)
minnoce944 is on a distinguished road
i have the bridgestone blizzak LM-25's. Got a flat the other day and found out my tire is not in stock anywhere and cannot be ordered since bridgestone stops manf them for the season. Even tried tirerack/ntb/sears/just tires, firestone-bridgestone stores, etc.
Currently i have the 225/40/18, the only close tire i can find is a lm-25 235/40/18. I was thinking i can buy 2 and use them for the back and keep the 225/40/18 for the front. Any problems with doing this? Is there a better recommendation/suggestion? Is it better to just buy a new set of 5 same size (spare this time) and cut my losses?
I noticed my default stock summer tires are 225/40/18 front and 255/35/18 rear. This would make me think its ok to run dif widths but am not sure.
Any help appreciated, i have a loaner from the dealer right now but i miss my car
Relevant car info:
BMW 335XI sports package with 18in rims
minnoce944 is offline   Reply With Quote
Old 12-24-2007, 08:54 AM   #2 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
i dont see a problem with running wider tires in the back
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 12-24-2007, 01:36 PM   #3 (permalink)
isherdholi's Avatar
isherdholi will become famous soon enough
The reason your rear tyres are wider, is because your rear wheels are wider. Your stock 18-inch wheels are most probably 18x8 at the front and 18x8.5 at the back.
The tyre widths you have are correct for the wheel width. I would not recommend putting different width tyres than the ones that you currently have, i.e. make sure your fronts are always 225, and make sure your rears are always 255.
isherdholi is offline   Reply With Quote
FS: Pirelli Winter 210 SnowSport winter tires with BMW steel rims (P205/60R15) WeatherB Wheels and Tires 3 12-09-2007 03:54 PM
Winter tires moe19x 3-Series (E36) 3 11-28-2005 06:39 PM
Winter Tires In Canada harpax 3-Series (E46, E90) 5 11-18-2004 09:04 AM
Buying Advice For Winter Tires dberger 5-Series (E12,E28, E34, E39, E60) 2 10-09-2004 04:37 AM
17" winter tires a good idea? GnarlyCow 3-Series (E46, E90) 12 06-24-2004 09:40 PM
