| Just be sure that the mirror selector switch is set to driver's side, then when you shift into reverse, the passenger side mirror will tilt down. If the switch is set to passenger side, then it won't tilt when shifted into reverse.
__________________ <span style='font-size:8pt;line-height:100%'><span style='font-family:Arial'>Warped Mind®
2004 330i</span></span> |
