Wind Noise In The Right Rear Window??? - BMW Forum - BimmerWerkz.com
Old 05-01-2005, 04:06 PM   #1 (permalink)
darthvedder is an unknown quantity at this point
At speeds over 60, you can her an air leak in the right rear window. I can't see any visual problems w/ the trim and window. I'm quite sure that the window regulator has been replaced... so that could be one of the problems.
darthvedder is offline   Reply With Quote
Old 05-01-2005, 05:35 PM   #2 (permalink)
toast_mcmann is an unknown quantity at this point
I had a high speed air leak as well. The most annoying part was that I was never really sure where it was coming from. I eventually replaced the windsheild and sure enough the last windshield was not installed properly. Now the problem has gone away.
toast_mcmann is offline   Reply With Quote
used 528: rear window & cam belt question jcmky 5-Series (E12,E28, E34, E39, E60) 1 10-16-2005 04:37 PM
Wind Noise, 2006 330i OneChance 3-Series (E46, E90) 1 09-19-2005 12:10 PM
Very Hot Spot On Wagon/touring Rear Window nv325xiT 3-Series (E46, E90) 2 01-25-2005 03:16 AM
Rear power window failure Minardi 5-Series (E12,E28, E34, E39, E60) 2 08-14-2004 01:23 AM
