i got underneath my car today to try to find the oil drain plug on my 328i. i see this huge cover covering the first third of the front of the bottom of the engine bay, and approximately near the center of this cover, i see a hole and through this hole appears to be a 17mm bolt head of some sort. is this the drain plug that i am looking for?? if not, then where the heck is it??
It's on the passenger's side of the oil pan. Do you know what the oil pan looks like?
__________________ <span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
Oh damn, I didn't realize this was e46 and not e36. Sorry bub, i gots an e36 so I'm 100% completely useless to you. MAYBE the e46 mod, or someone else, can answer your question for you ....
Originally posted by GreenDragon@Dec 18 2003, 12:14 PM Oh damn, I didn't realize this was e46 and not e36. Sorry bub, i gots an e36 so I'm 100% completely useless to you. MAYBE the e46 mod, or someone else, can answer your question for you ....
i belive the e46 oil pan is not covered, check again. youll see the plug
phillips head screw driver will get that cover out of your way. There's like 6 or 8 (forget exactly) silver phillips head screws holding that cover on. They are 1/2 scres so just twist and they spring out. This will gain you access to the oil pan and on the side at the bottom is a 17mm drain plug. DON'T FORGET THE COPPER WASHER ON THE PLUG
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
depending on the year, there maybe an access "flap" which is secured by one quick release fastenener. But, that usually ends up with a mess anyway; easier to just remove it anyway.
Everything BMW
Plano, TX 75074
469-767-3309
