Wheel and tire size - BMW Forum - BimmerWerkz.com
Old 12-06-2003, 06:07 PM   #1 (permalink)
blackbmw330 is an unknown quantity at this point
Hi,
Does anyone know if I can fit 18x8.5 wheel in the front and rear for 2001 330ci?
Also can I fit 245/40-18 size tires for front and rear? If not what would be the best?
Thanks!
blackbmw330 is offline   Reply With Quote
Old 12-06-2003, 06:17 PM   #2 (permalink)
AZ325Ci is on a distinguished road
yes, the 18x8.5 will fit on your car.
the recommended tire sizes are 235/35/18 for the fronts, but you can put on 245/35/18 on the rears.
AZ325Ci is offline   Reply With Quote
Old 12-06-2003, 06:35 PM   #3 (permalink)
Thanks Az! Also who you happen to know what the offset size I could use for 18s?
I don't really understand what offset is?
Old 12-07-2003, 02:26 AM   #4 (permalink)
distance between the center of the wheel (measured across the width of the wheel)and the hub (or where the wheel contacts the hub).
correct offset is critical, because if not properly centered the bearings will wear out in no time. i see this so commonly, especially on slammed ricemobiles. wheels absurdly sticking out...
weight of the car should be distributed almost at the center of the bearing. if the wheel is too wide, the weight moves to the outer edge of the bearing.
factory bmw alloys are guarateed to have correct offset. aftermarket : you need to trust the company you are buying from. tire rack is reputable, but i cannot really advise you on specific wheels as i do not know the offset for your car. i can try to remember and tell you how to measure offset on a dismouted wheel if you want.
peter
Old 12-07-2003, 02:52 PM   #5 (permalink)
GOODHUE330CI is an unknown quantity at this point
I HAVE A 2001 330CI AND I HAVE 8.5X17' IN FRONT AND 9.5X17" IN REAR AND 245-50-17 M-PILOTS ALL THE WAY AROUND SO I WOULD HAVE TO SAY YES
GOODHUE330CI is offline   Reply With Quote
Old 12-07-2003, 03:39 PM   #6 (permalink)
e36_m3_Turbo's Avatar
usin caps lock enough? jp .....but yes those tires will def. fit on a e46. you could put 19's on ur e46 if u wanted
No longer red.
Old 12-07-2003, 07:27 PM   #7 (permalink)
peter
Thanks for the explanation.
Is 40mm offset correct with 18in wheels correct for the 330ci? I seem ebay selling some 18in wheels with 40mm offset and they it said it should fit the 330ci. Does anybody know?
style 45 16" wheel w/ new michelin tire funtoos Wheels and Tires 2 09-06-2007 05:15 PM
Ahh..... The Age Old Question liltrig99 3-Series (E36) 11 08-04-2005 02:29 AM
WHEEL and TIRE Question JL380 3-Series (E36) 1 02-05-2004 09:36 PM
330xi winter wheel and tire size ///MONSTER 3-Series (E46, E90) 4 10-13-2003 08:45 PM
