Wheel Options On '04 330xi - BMW Forum - BimmerWerkz.com
Old 10-17-2004, 08:13 PM   #1 (permalink)
Pinkpanther is an unknown quantity at this point
Hello!
I have a 2004 330xi, manual, with 17" runflats that has pressure monitor. I want to change to either 18" or 19". What are my options and will this effect my awd system? Do these wheels work with the pressure monitor?
Thanks for your help
Pinkpanther is offline   Reply With Quote
Old 10-18-2004, 11:20 AM   #2 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
It should not affect the AWD system, and with the pressure monitor it depends on if the sensor can be transfered form the current wheel to the new wheel.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 10-18-2004, 01:10 PM   #3 (permalink)
Gulelin is an unknown quantity at this point
Check out the link I sent you in the PM, but you prolly have to roll the fenders for 18s, almost certainly for 19s. Shouldn't affect the AWD though, they stagger the wheel sizes on the XI in Canada at the dealers.
Titsilver metallic 2004 330 Xi 6speed manual
Gulelin is offline   Reply With Quote
Old 10-20-2004, 10:05 AM   #4 (permalink)
Red 330CiC is an unknown quantity at this point
[snapback]213417[/snapback]
Wheel size has nothing to do with overall tire dimensions, so as long as you don't exceed the max tread width and tire diameter, you can put 18's or 19's on with no modifications. Just select the proper tire size - i.e. sidewall height ("series") and tread width. One thing you don't want to change is your stock tire circumference (i.e. diameter), as this will affect your speedo and potentially your AWD traction control. Increasing diameter or tread width (beyond the max for your car) will require rolling the fenders and/or other serious mods that you don't need to get into. To determine your tire size for larger rims the calculations are simple. If you don't know how, the tire rack or any online wheel & tire store will gladly help you determine the proper (or max) size for your car.
2004 330cic, 6-Speed
Electric Red / Black Leather & Top
Sport, Premium, Xenon, Cold Weather packages
Alarm
18" Style #71 Wheel package
Red 330CiC is offline   Reply With Quote
Old 10-20-2004, 11:46 AM   #5 (permalink)
Although the tire diameter for my summer setup was slighty different for the front and rear wheels I didn't notice any adverse effects. This website has a calculator that will give you the actual dimension of the tire:
http://www.gordon-glasgow.org/tirecalc.html
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
Steering Wheel Options? gmal 5-Series (E12,E28, E34, E39, E60) 6 10-09-2004 11:24 AM
Rim & Wheel Options for a 2004 325Ci 2004BMW325Ci 3-Series (E46, E90) 39 01-10-2004 11:39 PM
330xi winter wheel and tire size ///MONSTER 3-Series (E46, E90) 4 10-13-2003 08:45 PM
