I decided to do change my brake pads, rotors and sensors myself. I followed the instructions
here. It was actually very easy except for one very small but very frustrating problem. I got to the last wheel and stripped the one bolt holding the rotor on! It'a a 6mm hex head (Allen) bolt. (Photos are from my cell phone so bear with me.)
This picture shows the normal rotor and bolt that holds the rotor in place:
Be VERY careful not to strip the bolt or you will have to do this:
As you can see, I had to weld another bolt on to get it out:
A failed attempt at creating a slot with a dremel tool for a flathead (could have worked if I hadn't butchered it!):
As you can see, my name is Joel (artwork by the friend with the welder):
Close up of the hack-job I insued while frustrated and clearly not thinking:
So, what I learned from this: Although I used WD-40 on everything before I loosened things, I should have waited longer and maybe used something designed especially for bolts. But the main thing was that I need to have some patience and a new allen socket wouldn't hurt.
By the way, anyone know why my E-brake barely works now? Like doesn't work on hills at all?
