Hey y'all--
Alright, do I have a low voltage problem, or what? When I turn the ign. on, they seem to work a couple of minutes, but then all of a sudden I'll go to center-off on the turn signal lever, but it won't turn off. The other thing is, it seems to want to default to the left side--that is, even if I just switched on the right blinker, if I go to center, the left blinker will come on.
used:
Now, if I start the car, the problem happens within a minute or two of running, and blinker will come on ALL BY ITSELF
Does anyone have a clue? And, could this tie in with a trans. shifting problem after a few minutes of running and a malfunction light for the trans.?
Well, I'd defintely appreciate a coffee and a scratch on the head for this.
Thanks,
441tech
