water in passenger cabin - BMW Forum - BimmerWerkz.com
Old 07-03-2006, 03:41 PM   #1 (permalink)
FL325i is an unknown quantity at this point
'03 325i premium pkg. sunroof. We're getting water on the driver's side floor in the front and the back. Any ideas where/why it's getting in? The trim piece above the windows on both sides of the car has a small gap, as if the piece has shrunk. I'm guessing this is not the source. Thanks for any help. It goes to the dealer under warranty on Thursday...
FL325i is offline   Reply With Quote
Old 07-03-2006, 04:49 PM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Have the moonroof gaskets/seals checked. If water is making it inside through there, it could funnel its way to the a and b pillars, ending up in the carpet.
This has been known to happen in other BMWs.
Turkey Fleet Bond Holder
Old 07-03-2006, 11:55 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
IF the window regulators have been replaced on that side then often times the vapor barrier (large gray foam looking barrier that seals the inside of the door) will either get torn or possibly just not re-installed correctly. Also sometimes they can just leak on their own. The only way to tell is to remove the door panel and inspect the vapor barrier for leaks. This is one of the most common e46 water leaks.
DT
DT
Old 07-06-2006, 12:45 PM   #4 (permalink)
325isBaby's Avatar
Car: 2005 330xi
I'm going to go with DRZ on this one, I've seen this happen most commonly after the sunroof has been worked on.
Come see me at MySpace
Old 07-06-2006, 01:41 PM   #5 (permalink)
Thanks for the replies. It was supposed to get checked out at the dealer today, but they didn't have a loaner car as promised. Counter guy had to deal with my wife for that.
The driver's side regulator was changed around Christmastime, but it hasn't leaked until recently. I do have a moonroof. It hasn't needed any work yet. I'll let you know...
Old 07-11-2006, 08:50 PM   #6 (permalink)
The dealer went for the window regulator. Not just the vapor barrier...they replaced the regulator. So far, no water, and it's like monsoon season down here!
Old 07-20-2006, 10:21 PM   #7 (permalink)
Leak free still...
Old 08-03-2006, 06:42 PM   #8 (permalink)
Let me amend a previous post. After seeing the work order the only thing done was replacing the vapor barrier properly. Again, no more leaking!
Coolant Question dvmotorsports 3-Series (E36) 6 06-10-2005 09:31 PM
Pool Of Water In Cabin BM_boy 3-Series (E46, E90) 0 10-24-2004 02:58 PM
Water in my car!!! Tknojnky 3-Series (E46, E90) 14 01-21-2004 07:43 PM
