Water in my car!!! - BMW Forum - BimmerWerkz.com
Old 12-20-2003, 09:10 AM   #1 (permalink)
Tknojnky is an unknown quantity at this point
Hello all, I recently bought a 99 323i and it just started raining in my area. I am freaking out because there is a significant amount of water getting into my car, and I cannot find the source! I have checked the front drains in he sunroof, and also the drains in the cowl. Those seem fine. The water comes out under the car and through the gap between the side skirt, and the fender. I haven’t been able to get to the back drains on the sunroof, is there a trick? Also any other things I should check? I know some people have had their AC drain tube come loose, but that is usually associated with water on the passenger side of the car. I have quite a bit of water in the foot well of the drivers side, and some in the back on the drivers side. But I think water only gets to the back of the car if the front is "full". By full I mean soaked, there is no visible water line above the carpet, it is just soaked.
Any help would be greatly appreciated..
Tknojnky is offline   Reply With Quote
Old 12-22-2003, 12:04 AM   #2 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
well i have had water leaks coming in from my doors the vaper barrier in the doors have to have a tight seal otherwise overflow water comes through. I will be replaceing them when i receive them. This problem is common to happen to these cars if there is work done in the doors and the dealership morons slap it back on hap hazardly.
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 12-22-2003, 12:21 AM   #3 (permalink)
one other less likely possibility is the lower seal on the windscreen (this happens commonly if the car was in an accident or the windscreen was replaced).
have one guy pour water from a hose on the windscreen, ant other guy stick his head in the driver footwell and watch for water on the firewall behind the carpeting. i do not think you can see the seam itself.
peter
Old 12-27-2003, 10:10 AM   #4 (permalink)
Snowjob's Avatar
Snowjob is an unknown quantity at this point
you ever figure out what the problem was?
Snowjob is offline   Reply With Quote
Old 12-30-2003, 12:04 AM   #5 (permalink)
BlackTape's Avatar
BlackTape is an unknown quantity at this point
Send a message via ICQ to BlackTape Send a message via AIM to BlackTape Send a message via MSN to BlackTape Send a message via Yahoo to BlackTape
the dealerships jerry rig your car so you come back... those bastards
<img src='http://www.satchmo.com/cashmoney/btymers.jpg' border='0' alt='user posted image' />
<span style='font-family:Impact'><span style='font-size:21pt;line-height:100%'><span style='color:red'> GANGSTA Tape</span></span></span>
BlackTape is offline   Reply With Quote
Old 12-30-2003, 01:30 PM   #6 (permalink)
Heh.. not exactly.
I got a chance to take both drivers side doors apart, and found that the vapor barriers were intact. They had been removed previously, but I couldn't find any gaps in the seal at all. It looks like whoever put them back on used silicon to reseal them. So, now I'm back to my clogged drain theory. Anybody have info on the rear drainage system?
Old 01-06-2004, 12:21 AM   #7 (permalink)
Well, over break I was able to tear my car apart and pull back the carpet. So far, I have been trying to dry it out for the past 2 days. I put a small heater in there, and a fan. I'd say it is about half way dry at this point. This really sucks! I want to drive my baby!!!
I have come up with a plan though. I think I will get in the car, and close it up. Then have a friend start at the front, and work his way back with a hose. I just hope I will be able to see where the water is coming in, and fix the problem now that I have the carpet peeled back.
Anybody know if there is something in particular I should be looking for? Or should I just wing it and hope for the best?
Old 01-06-2004, 08:33 PM   #8 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
just do it.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-07-2004, 12:34 AM   #9 (permalink)
BlackTape's Avatar
hoever buys your car don't show them this thread!
Old 01-07-2004, 11:04 AM   #10 (permalink)
Well, I am going to fix the problem, so it's not a big deal.
Old 01-07-2004, 12:36 PM   #11 (permalink)
ArchaicAngel is an unknown quantity at this point
You could also try running it through a "hands free" carwash where it just shoots high powered water, that might show more than a hose. But it also might get more water in...I dunno...
<span style='color:blue'>2000 323i Sport Wagon (yeah, I got the wagon!)
Remus Sport Exhaust w/ Ralley Tips
Smoked Clears
10&quot; Kappa Perfect 10.1
1000w Kenwood Amp</span>
ArchaicAngel is offline   Reply With Quote
Old 01-11-2004, 09:50 AM   #12 (permalink)
Well, if anybody is interested, it ended up being the front drivers side door seal. I guess there was a small gap in the seal. Got the problem all fixed, and the carpets all dry.
Removing all that water must have added more HP cause she is faster then I remember. :P
Thanks for the advice guys.. Case closed..
Old 01-21-2004, 12:41 PM   #13 (permalink)
Fangs's Avatar
Fangs will become famous soon enoughFangs will become famous soon enough
Aren't there double seals on the doors - one on the door and one on the jamb??? At least mine does...
Glad to hear you got it fixed. How much did the new seal cost? Was it a pain to switch out?
<span style='font-size:12pt;line-height:100%'><span style='color:blue'>I don't drive fast,</span> <span style='color:red'>I FLY LOW</span></span>
'99 323i
'02 540i
Fangs is offline   Reply With Quote
Old 01-21-2004, 07:35 PM   #14 (permalink)
TECH's Avatar
The last thing we want to hear is that a customers car has water leaking into it, especially if it was just worked on for say, oh, a window regulator... :P
Any time I do a window regulator or work in the door, I never remove the bottom portion of the vapor barrier.....my work don't leak.
Old 01-21-2004, 07:43 PM   #15 (permalink)
TECH's Avatar
Tknojnky, I wouldn't count out the vapor barriers just yet. I can almost guarantee you that the water is coming from there. It's easy to test this.
Get your water hose, without a nozzle. Open the door you want to test. Run a slow stream of water all over the outside of the window glass. Water won't splash everywhere if you keep the water stream moderate. Do that for a minute or so, and then look inside the door at the bottom of the door panel. If you see any wate coming out from between the door panel and the door, you have a problem. This water will just drain into the car without you seeing it with the door closed. When it rains, it doesn't take a major leak to get things wet.
All the water that goes down the outside of the window will drain into the inside of the door. The vapor barrier is what keeps it at bay until it can make it's way down to the bottom of the door, where the drains are. The water rolls down to the bottom of the vapor barrier and comes in contact with the glue that holds the barrier on. If there is evene the slightest opening in that glue, you have a leak.
I hate this design. It royally sucks to deal with. I've pulled seats and carpet before because of this.
5 series will do it to-E39, but not nearly as common.
Coolant precision0904 3-Series (E36) 12 02-09-2011 10:15 PM
Potential water damage vitorago 5-Series (E12,E28, E34, E39, E60) 6 10-16-2005 06:24 PM
Coolant Question dvmotorsports 3-Series (E36) 6 06-10-2005 09:31 PM
Leaky Water pump or the Themostat Housing RedBeemer95 3-Series (E36) 12 08-21-2004 07:13 PM
