Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 09-27-2004, 04:27 PM   #1 (permalink)
Photos: 0
eris is an unknown quantity at this point
I need to fix windows regulators on my car, and it's covered under certified warranty, but i had tune-up done some place else, and mechanic couldn't reset the computer indicating milage for the next tune-up. Will the dealership tell me that i can't use warranty anymore?
Thanks!!
eris is offline   Reply With Quote
Old 09-28-2004, 10:41 AM   #2 (permalink)
dbtheo's Avatar
Photos: 0
dbtheo is an unknown quantity at this point
No, UNLESS there is a clause is your warranty that states you must get the work completed there. Read your papers first, then figure out what you need to do. You can also simply purchase a "reset" tool from www.bavauto.com or some other places, so you can do it yourself.
<img src='http://photos.e46fanatics.com/data/500/17560Sig34.jpg' border='0' alt='user posted image' />
dbtheo is offline   Reply With Quote
Old 09-28-2004, 11:13 AM   #3 (permalink)
Photos: 0
2001BMW330iRob is an unknown quantity at this point
RESETTING OIL SERVICE INDICATOR:
If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again:
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
http://www.my330i.com/lof.php
2001BMW330iRob is offline   Reply With Quote
vB code is On
Warranty Question G_Anders 3-Series (E46, E90) 2 03-16-2005 07:09 PM
Warranty Question J325ci04 3-Series (E46, E90) 0 10-22-2004 11:04 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
