Ok, so I get some CCFL Angel Eyes for my car. Installation is supposed to be simple and for the most part it is until I get to part where I have to connect them to a power source. The instructions say "take out the parking light and connect it to the plug. Then replace the parking light." Sounds simple right? Here is the kicker. Isn't the parking light the same light as the blinker? So if I connect to that bulb my eyes will only blink when I am turning? Not to mention the wies will not reach. Is the parking light really the blinker? If so, which wire is positive and which is negative?
Seriously is there a power supply closer to the high beams that I could splice into. I think these only need about 5Watts of power?
SOme other notes with this: Is it possible to turn off the daytime running lights without going to the stealership?
If you like DIY stuff check the e46 fanatics forum. They have a pretty extensive catalog on DIY projects.
