| Vanos? DME ? Idle problems P1347 and P1352 codes Hi,
I'm a new member in this forum and hope you guys can give me some help on a new problem in my 2001 BMW 330i, the engine service soon light came on, and also I can tell I have a misfire feeling the shaking after 5 second of started on , I hook up the computer and have the P1347 and P1352 faults which means misfire on Cyl 3 and 6, Replaced all spark plugs,swap coils,and nothing better. Noticed that inyector #3 was not working so I replaced for a new one, still not working !!......checked voltage came from DME and not voltage was going to energize this injector. After read the manual it said that the DME will cut the fuel for the cylinder affected if know which one can be cause a major problem later. SO I'm stuck on it, I read about Vanos problems here and there, I read about DME need to be reprogramed.....Have you seen anything like this before?, I will apreciated your help...thanks very much in advance.
Ivan
(Dallas-Texas/USA) |
