Uh Oh...Rear Differential Problems... - BMW Forum - BimmerWerkz.com
Old 08-09-2008, 04:02 PM   #1 (permalink)
441tech's Avatar
441tech is on a distinguished road
Here's the dealio:
I've had a vibration in the rear end for sometime, and has recently gotten worse. I put it on jacks and hand-spun the rear wheels, and it sounded like a rythmatic, rotational flat-spotted bearing inside the diff. Car is a '99 323i with 165,000 on the ticker. Does anyone know of these having diff. problems later in their life? The vibration can be felt at all speeds, but is the worst between 30 and 40mph, and when accelerating it is amplified. It also gets amplified around corners. I know it's in the diff. because I disconnected the output shafts and rotated the driveshaft and it still made the same noise.
Here's what's been replaced since I've had the car:
- Front struts and rear shocks
- Trans./driveshaft rubber coupling
- Center carrier bearing assy.
- Rear wheel bearings
- All brakes and related components
- Wheels and tires
I did not check the fluid level, nor has it ever been replaced to my knowledge. However, the entire diff. and surrounding area are bone dry...No signs of any leaks. The only thing I haven't replaced are the output shafts...The inboard joints at the diff. felt a little worn and stiff, but as I mentioned before, the noise still comes from the diff. with the shafts disconnected. And yes...I'm going to replace the output shafts - To my knowledge, they are the originals as well. Expensive buggers, though.
I guess my question(s) is: What's the problem? Bearings in the diff. housing? Gears? Old Age? Is my differential repairable, or should I just call some 'yards and try to find a low-mileage diff? Does BMW have a reman program?
Any help/insight would be greatly appreciated.
Thanks in advance.
441tech
Officer: "I see you set the table for four."
Groucho Marx: "That's nothing--I set my alarm clock for eight."
441tech is offline   Reply With Quote
Old 08-10-2008, 02:36 AM   #2 (permalink)
Car: BMW Individual2001 E46 325CI manual
sprintman is on a distinguished road
Always replace diff and g'box oils regularly. OEM stuff isn't that good to start with and 'lifetime fill' is total bs.
sprintman is offline   Reply With Quote
Old 08-10-2008, 05:49 PM   #3 (permalink)
441tech's Avatar
So would it do any good to change the fluid now? My guess would be no, since I would imagine the damage is already done.
BTW...What's a good fluid for this diff?
441tech
Old 08-10-2008, 05:58 PM   #4 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
^ sounds like it is already dead.... sounds like it is time to upgrade to a LS(Limited Slip) unit!
1992 318i Coupe parts car
I am Captain Obvious
Old 08-10-2008, 06:06 PM   #5 (permalink)
441tech's Avatar
Shiza...I didn't know you could get a limited slip. In fact, I thought that was already in there since everytime I broke 'em loose both wheels started diggin'...Where's a good place to get replacement diffs?
441tech
Old 08-10-2008, 07:47 PM   #6 (permalink)
Redline 75W90 is good imo.
Old 08-11-2008, 01:03 AM   #7 (permalink)
This is a nice Non lsd unit if you need a replace ment quick
eBay Motors: BMW 3.46 NP Rear Differential E46 325 325i SEDAN (item 220250450740 end time Aug-24-08 14:54:53 PDT)
I'll look for a LSD unit for you to if you decide to go that route...
Old 08-12-2008, 02:51 PM   #8 (permalink)
441tech's Avatar
Thanks Alpine!
Looks like a pretty nice unit...Are they reliable? Have you ever bought any of their reman stuff? I'm assuming this is a reman unit...And if you wouldn't mind, I would like to know where to get an LSD unit...
441tech
Old 08-12-2008, 09:24 PM   #9 (permalink)
thanks friend bought a diff for his 318i and it worked till he crashed it
I'm still looking for a Lsd unit i havn't forgot about you
Old 08-16-2008, 01:41 PM   #10 (permalink)
titaniumbullet's Avatar
titaniumbullet is on a distinguished road
Send a message via MSN to titaniumbullet Send a message via Yahoo to titaniumbullet
you need to replace it.... its gone..... I would do an upgrade LSD (limited slip diff) make sure you maintain the fluids and what not so your not running into this in the future.
My favorite BMW rims
titaniumbullet is offline   Reply With Quote
Rear Differential nookatee 3-Series (E36) 6 02-24-2005 09:33 AM
Possible Differential Problems?! SuperFreaks 323is 3-Series (E36) 0 11-06-2004 08:29 AM
Rear axle differential TheFutt 3-Series (E36) 4 08-06-2004 02:23 PM
