| Get up in the morning, when the temperature and tires are both cool. Check the tire pressure. Read the side walls on the tires, and fill/ deflate them to what the tire says. Make sure you do it when it is COOL. When the tires are hot, the pressure rises, and gives you a false reading. And remember it is always better to be a couple psi over, than 1psi short (unless your dragging/ racing or something).
edit: if they still wrong, you could have bad tires/ sidewalls etc. get them checked
__________________ <img src='http://photos.e46fanatics.com/data/500/17560Sig34.jpg' border='0' alt='user posted image' /> |
