Turn signal switch replacement - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 08-22-2009, 01:26 AM Thread Starter
beefrank's Avatar
beefrank is on a distinguished road
The turn signal switch needs replacement on my 99 323i. The right turn signals are continuously on until I either activate the left signals or the hazard switch. I have encountered similar problems with my 2002 and easily replaced the turn signal switch. How do you remove the steering column covers? Can this be done without touching the air bag mechanism? Does the horn and steering wheel have to be remove? Is this a DIY task or should I prepare to spend a couple of hundred at the local BMW dealer for a day's work?
beefrank is offline
post #2 of 3 (permalink) Old 07-30-2011, 02:36 AM
kirbylawrence is on a distinguished road
You must switch off the airbags and mark and remove .and Yes the steering wheel has to be pulled. Though I think this is not a DIY job.Good Luck
kirbylawrence is offline
post #3 of 3 (permalink) Old 07-31-2011, 12:37 AM Thread Starter
beefrank's Avatar
Thanks for the reply. I found a step-by-step illustration from the E46Fanatics forum and was able to replace the turn signal stem in 30 minutes. Very easy as long as you have the proper tools including the torx bits which I already had. Here are the instructions.
The final OBC retrofit thread - E46Fanatics
beefrank is offline
Gear in this thread - Powered by O'Reilly Auto Parts
steering wheel!! turn signal switch pinnaclebass 3-Series (E21, E30) 3 05-23-2008 04:19 PM
Turn Signal Switch Swap snpower 3-Series (E21, E30) 0 03-07-2008 06:44 AM
Turn Signal Help e36_m3_Turbo 3-Series (E21, E30) 2 09-24-2005 04:17 PM
Turn Light Signal Switch Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 0 08-12-2005 12:24 PM
Turn Signal joeh52 3-Series (E46, E90) 3 09-10-2004 09:24 PM
