Turn signal problems - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 08-22-2004, 05:10 PM Thread Starter
beau is an unknown quantity at this point
I was driving down the freeway and my bulb out indicator came on. The next time I used my turn signals it was blinking fast becasue of a burnt out bulb. I replaced the bulb and when I turned on the turn signal it blinked fine 2 or 3 times then started blinking fast again and the indicator came back on. Was the second bulb a bad one or is this a larger problem?
beau is offline
post #2 of 4 (permalink) Old 08-22-2004, 05:28 PM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
Did you take the bulb out again to see if it was bad?... Burnt up or something... ????? fast blinking turn signals usually mean it is grounding out some where.. thats just what I've come to know.. hope this helps some.
Les
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #3 of 4 (permalink) Old 08-22-2004, 05:58 PM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
on e46 it is very common for the bulb socket to corrode or get burnt and cause intermittent probs. inspect the bulb socket (holder) for any signs of burned or corroded contacts and if so replace the socket and you may possibly need to replace the bulb itself again if it has become burnt again from the bad socket.
DT
Dirty_Tool is offline
post #4 of 4 (permalink) Old 08-22-2004, 10:22 PM
woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute woobiee has a reputation beyond repute
Send a message via AIM to woobiee
make sure you are putting the right bulbs...ID/version numbers, double fillaments...etc.
woobiee is offline
Turn Signal Problem, stuck on, not blinking. jek1955 3-Series (E36) 2 10-27-2005 07:48 AM
Turn Signal Issues Help warell 3-Series (E46, E90) 4 01-20-2005 03:57 PM
1984 528e Turn Signal Questions. rock_martyr 5-Series (E12,E28, E34, E39, E60) 1 11-10-2004 12:47 AM
Turn Signal Regulator eclypser 3-Series (E36) 1 09-04-2003 03:30 PM
97 328i Turn Signal Relay dhruvm 3-Series (E36) 0 09-02-2003 05:18 PM
