Turn signal light bulb - BMW Forum - BimmerWerkz.com
Old 04-01-2004, 10:30 AM   #1 (permalink)
Blackdog is an unknown quantity at this point
Thumbs up
Okay, I have read my owners manual and I am still confused about changing the front turn signal light bulb. Can any one tell me what holds the light assembly to the car and how do I get it off to change the bulb?
Thanks,
Kenny ghead
Blackdog is offline   Reply With Quote
Old 04-01-2004, 10:43 AM   #2 (permalink)
Graphic Designer's Avatar
Graphic Designer is an unknown quantity at this point
Send a message via AIM to Graphic Designer
its only one screw that holds it in place. in the very corner near the back of the lamp, look down one of those holes, you will see a screw. use your phillips to unscrew it, not all the way, then slide your corner lamp out to the front.
take a pic of the front area and i will circle where.....
garpihc dseigenr
(sp)?
Graphic Designer is offline   Reply With Quote
Old 04-01-2004, 11:40 AM   #3 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Here is another thread about changing the front turn signal indicator. Their is some good info enclosed. On an e46 no screws need to be removed to free the front corner blinker, just a tab needs to be depresed and the corner pops out.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 04-01-2004, 11:44 AM   #4 (permalink)
Ben
??really??
well mine had a screw? what e46 do you have?
garpihc dseigenr
(sp)?
Old 04-01-2004, 11:47 AM   #5 (permalink)
Mach 5's Avatar
2000 328ci I had no screw to remove and have never seen a screw for the turn signal. The sedans may be different or the facelift could have changed how the lens is held in. But I have only a tab that locks into the headlight assembley.
Ben
Old 04-01-2004, 11:51 AM   #6 (permalink)
yeah. we are both right.
blackdog, if you a sedan, yes there is a screw
and if you have to 2dr, then no, there is no screw but a tab...
hope this helps.
garpihc dseigenr
(sp)?
Old 04-01-2004, 12:01 PM   #7 (permalink)
I have a 2002 323IT. When I look down that oval hole I see a round disk that you can turn with a skrewdriver. Is this the thing that I need to turn?
Thanks for the replies.
Kenny
Old 04-01-2004, 12:32 PM   #8 (permalink)
yes, its white with a screw in the middle. the hole would be in the fender where you would put the phillips through...
you dont need to unscrew it all the way. just about halfway and the lamp should slide right out...
install, reverse directions. but dont over tighten the screw...
garpihc dseigenr
(sp)?
Old 04-01-2004, 12:38 PM   #9 (permalink)
exjarhead328's Avatar
exjarhead328 is an unknown quantity at this point
just to add fuel to the fire, I have a 2000. 328 4 door with no screw.
SEMPER FI 2/3 Comm
Founder of the Four Pedal Club
2000 328
exjarhead328 is offline   Reply With Quote
Old 04-01-2004, 01:07 PM   #10 (permalink)
should pull right out then... look for the tab...
if you would take a picture, i can help you alot better.
garpihc dseigenr
(sp)?
Old 04-01-2004, 01:09 PM   #11 (permalink)
come to think of it. if you wait til tomorrow i can take a picture of it. i have 2000 4dr 328 also. but i wont be home til 10pm tonite....so just wait til tomorrow and dont go break anything.
garpihc dseigenr
(sp)?
Old 04-02-2004, 08:18 PM   #12 (permalink)
gonzo499's Avatar
gonzo499 is an unknown quantity at this point
you all gotta check this out. you may have already found it but there is a ton of handy DIY instructions for the e46 here
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1081744190.jpg' border='0' alt='user posted image' />
<span style='color:gray'><span style='font-family:Arial'>2000 323Ci alpine white</span></span>
gonzo499 is offline   Reply With Quote
Old 04-04-2004, 11:04 AM   #13 (permalink)
AZ325Ci is on a distinguished road
i don't mean to hijack this thread, but some e46's have a screw and some just a tab. i have the 2-door coupe and mine has a screw.
AZ325Ci is offline   Reply With Quote
Old 04-04-2004, 11:44 PM   #14 (permalink)
OH. blackdog, did you catch that?
garpihc dseigenr
(sp)?
Old 04-05-2004, 12:22 PM   #15 (permalink)
Cool
Thanks guys. I stuck the skrewdriver in that hole that I could not see into and prest down on a plastic tab, and that did the job. Thanks again!
Kenny :P
Turn Light Signal Switch Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 0 08-12-2005 11:24 AM
Turn Signal And Back Light Issues bmwbob 3-Series (E21, E30) 0 02-15-2005 03:49 PM
Turn Signal Bulb just_program 3-Series (E36) 10 01-17-2005 02:05 PM
