here's the deal... you have to look waaay down in the hole in the front of the top of the fender.
you will see a tab that you are looking at the top of - it is vertical - DO NOT try and push on this one.... it it way past that...
if you use your repair kit screw driver, it will be further down than it can go without taking the handle off...
push down - this will compress a spring that holds it in. it will just slide right out if you have it right...
then manual sucks - it took me a couple hours to finally figure it out (maybe I am just dumb).
this helped me finally get it.
