transmission problems - BMW Forum - BimmerWerkz.com
Old 08-15-2008, 05:23 PM   #1 (permalink)
medalla is on a distinguished road
How everybody doing?
I own a 2000 328i, the car was driving fine till I shift the car in drive gear and i heard a bang noise from the differential, suddenly all instrument lights comes on. Then the car stop shifting gears and went to default mode, stayed in one gear probably 3rd gear, I reseted the codes, but still doing the same thing, won`t shift gears. Does anyone have an idea what could be the problem? I will greatly appreciate your help!
Thanks
medalla is offline   Reply With Quote
Old 08-16-2008, 12:18 PM   #2 (permalink)
titaniumbullet's Avatar
titaniumbullet is on a distinguished road
Send a message via MSN to titaniumbullet Send a message via Yahoo to titaniumbullet
If your car is an auto then you may have an issue with your torque converter.... for those cars I believe you have the SMG ( sequential manual gear box ) try driving with that for a while but basically it sounds like your tranny is going transmission slippage usually ALWAYS leads to problems.... Id personally invest in a tranny/dif rebuild or new(er) tranny/dif.
My favorite BMW rims
titaniumbullet is offline   Reply With Quote
Old 08-16-2008, 09:27 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
get you car scanned and let us know what the codes are thts a better way than guessing
Old 08-19-2008, 10:41 PM   #4 (permalink)
These are the generic codes:
p0135
p0141
p0155
p0161
p0600
p1145
Also I found the o2 sensor wire grounded at the exhaust manifold and then all the trouble started.
Old 08-19-2008, 10:42 PM   #5 (permalink)
Thanks guys for the help!!
Old 08-21-2008, 06:51 PM   #6 (permalink)
I need an ECU looks like. I replaced o2 sensors and those codes are reseted so far. I still have the warning light on and runs in 3rd gear. Maybe master reset will do?
Old 08-22-2008, 09:52 AM   #7 (permalink)
Red face
all the codes mentioned in your previous posts point to 02 sensor problems; except for P0600 which is a serial data loss. P1145 is an electrical problem with your solenoid valve- methinks just a loose connection if u tie this code in with P0600.
I don't think tranny is at fault; it will surely show in the scan if it is.
I suggest looking over all your connector sockets ans see to it hey are snug n tight.
try to disconnect battery overnight. Hopefully this will reset ur tranny module(if that is the prob).
** make sure u have your radio codes in hand before u disconnect battery-otherwise, your radio won't play on the re-connect.
Old 08-24-2008, 09:29 AM   #8 (permalink)
cards2323 is on a distinguished road
reply
2001 325i, 80,000, I had the same thing happen to me today.
When I started it up the transmission sort of bumped into gear. The battery light flashed, warning brake lights indicators came on, transmission warning light, radio lights went out. I drove it home and the transmission still goes into safe mode.
Last week I had the alternator replaced??????
cards2323 is offline   Reply With Quote
Old 08-26-2008, 10:05 PM   #9 (permalink)
Found problem, got me a wiring diagram and discovered that there is a black fuse box inside the ecm compartment box. You have to check those fuses. That`s where I found the blown 30 amps fuse. check that out.
Old 08-26-2008, 11:33 PM   #10 (permalink)
sycow is an unknown quantity at this point
Hi ! can you tell me, where is located ecm compartment box, please ?
sycow is offline   Reply With Quote
transmission problems slick8541sniper@hotmail.c M-Series (M1, M3, M5, M6) 0 11-18-2006 02:54 PM
Transmission Problems ben_t 5-Series (E12,E28, E34, E39, E60) 1 01-18-2005 06:43 PM
Acceleration / Transmission Problems acerche 3-Series (E36) 8 01-07-2005 04:00 PM
transmission problems.. maybe?? akolang 3-Series (E36) 10 02-01-2004 11:11 PM
Transmission problems sb93lx50 5-Series (E12,E28, E34, E39, E60) 0 09-29-2003 07:24 PM
