Transmission fluid change for 323i - BMW Forum - BimmerWerkz.com
Old 10-11-2012, 12:27 AM   #1 (permalink)
Car: 2000 BMW 323i
bimmer323i is on a distinguished road
I'm pretty new to this so bare with me. I have a 2000 BMW 323i manual transmission and I was wondering if there is any difference between changing transmission fluid/rear differential fluid for automatic and manual transmissions?
I've been meaning to change these fluids myself for awhile now since I have 107k miles now and I haven't changed it since I got the car. I've been doing some research on the internet and im getting a little confused on the different fluids, transmission oil filters, etc.
If someone could please clarify this for me and tell me exactly what I need to get and do as far as procedure goes, it would be much appreciated.
Thanks in advance.
bimmer323i is offline   Reply With Quote
Old 10-11-2012, 09:44 PM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Its quite straight forward. First, you need to figure out what transmission model you have. Not auto or manual, but the actual type of transmission. Their should, key word being should, be a sticker on the bottom of the transmission pan. This sticker will tell you what transmission fluid to use based on which one you have. A green label generally denotes that Dexron III ATF is sufficent.
This is what the sticker on my 98 E36 looks like. Ignore the "lifetime fill" crap.
The vehicle needs to be level, and the fluid needs to be warmed up to operating temp before being drained. Always make sure you can remove the fill plug before you remove the drain plug. The link below is for a good DIY:
ATF Change DIY/FAQ (Pictures) - E46Fanatics
This is a thread about how the fluid isnt lifetime. Good read, but not too relevant.
The Verdict Is Here: E46 Auto Transmission Fluid Change (Pics and Lab Report) - E46Fanatics
Click HERE to see my E36 Blog
e38 transmission fluid change cuanza New Members Check In 11 07-22-2012 02:12 PM
2 change or not 2 change Auto Transmission Fluid chapps 3-Series (E36) 1 02-24-2009 06:45 PM
Transmission Fluid Change raakevin 5-Series (E12,E28, E34, E39, E60) 2 11-16-2008 03:31 AM
94 540-i - Change Transmission Fluid? 94-540i 5-Series (E12,E28, E34, E39, E60) 0 10-30-2008 03:41 PM
323i Transmission Fluid Hunter22 3-Series (E36) 4 04-18-2005 12:22 PM
