Tires and Alignment - BMW Forum - BimmerWerkz.com
Old 03-05-2006, 04:24 PM   #1 (permalink)
KeithinAL is an unknown quantity at this point
Tires and Alignment
2002 325IT and the front tires have worn completley out in the center in a very short time. Normally overinflation? Since I am replacing tires, where would you recommend an alignment? I bought the tires at NTB. How are they? Any experience? Would you suggest anyone other than the dealer?
KeithinAL is offline   Reply With Quote
Old 03-07-2006, 06:33 AM   #2 (permalink)
normal??? overinflation. how high do you run them, this sounds like way above 35. what is "short time", miles?
yes, alignment always. ntb barely competent. tirerack usually better selection and prices. if you do not knwo a trusted bmw mechanic, delaer for alignment is a fine choice.
Proper Alignment is VERRY Important! Eric S. 5-Series (E12,E28, E34, E39, E60) 6 12-27-2005 06:43 PM
Just a little story & an Alignment? Red93B3M2W5i 3-Series (E36) 6 09-19-2005 08:47 PM
Tire Wear and Alignment Dave-T 3-Series (E46, E90) 1 09-08-2005 12:46 PM
Front Drive Shaft Loose On 325xi bmw_in_maryland 3-Series (E46, E90) 4 01-13-2005 06:44 AM
HELP: 323 Alignment Fangs 3-Series (E46, E90) 2 12-10-2003 02:50 AM
