Tires - BMW Forum - BimmerWerkz.com
post #1 of 21 (permalink) Old 12-04-2003, 09:02 AM Thread Starter
KDM323i's Avatar
KDM323i is an unknown quantity at this point
Any suggestions for new tires. ghead
My other love besides my bimmer is my Harley !!!!!!!!!!
KDM323i is offline
post #2 of 21 (permalink) Old 12-04-2003, 09:07 AM
Mach 5's Avatar
Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute
Yokahama AVS Sports for UHP, or I have the ES 100's. I like the way they ride and were less expensive than the Conti sport contact 2's and BFG's that they replaced, are quieter also.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline
post #3 of 21 (permalink) Old 12-04-2003, 09:24 AM
KingScare's Avatar
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
yep i agree...for summer conditions the Yokohama AVS tires are really nice...good rain capabilities too. Just look at that thread!!!
V
V
V
V
KingScare is offline
post #4 of 21 (permalink) Old 12-04-2003, 11:00 AM
99E46's Avatar
99E46 is an unknown quantity at this point
I agree Yokahama AVS Sports are nice tires, but to keep your options open you might also look into some Michelin Pilot Sports. I have a set on my car, and they seem to be a good all around tire as well.
<img src='
</div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE </td></tr><tr><td id='QUOTE'>You are marvelous! I would like to nominate you to NWS pron master! </td></tr></table><div class='signature'><span style='color:blue'>From this thread</span> <a href='
target='_blank'>
style='color:blue'> Don't click if you will be offended
I love rope lights! YUM YUM</span>
99E46 is offline
post #5 of 21 (permalink) Old 12-04-2003, 11:37 AM
blackbmw330 is an unknown quantity at this point
I also use Pilot sports. Very good tires. Just a bit pricey but I think they will last longer
blackbmw330 is offline
post #6 of 21 (permalink) Old 12-05-2003, 12:03 AM Thread Starter
KDM323i's Avatar
Well I need a real good all around tire. I live in PA and its snows here. Thanks for the reply guys!!!
One more thing....... Can someone explain the size and what it means?
Original Equipment is for a 225/50 R16 and on her now is 205/55 R16??????? WTF?
ghead
KDM323i is offline
post #7 of 21 (permalink) Old 12-05-2003, 02:51 AM
KingScare's Avatar
"all around" tires are only good cuz they end up costing you less...
But you lose out on alot. They dont out perform a good summer tire, and they typically dont cut it in serious winter condition. I dont know how bad it can get in PA...but if you get snow and a good amount of it...it would be much wiser to invest in a REAL winter tire and a REAL summer tire...
but thats just my opinion.
post #8 of 21 (permalink) Old 12-05-2003, 03:24 AM
second that.
it can be cheap if you have a 325 car not 330. 325 have small discs and can take odler style steel wheels, so a set of snows mounted on them will be around $600 total.
then you can get whathever summer tyre the guys recommended on the eom alloys.
peter
peterkulesza is offline
post #9 of 21 (permalink) Old 12-07-2003, 01:21 PM
99E46's Avatar
Original Equipment is for a 225/50 R16 and on her now is 205/55 R16???????* WTF?
ghead
OH boy does it snow in PA! :lol: I used to live in Latrobe(home of Rolling Rock beer B) ), about an hour away from Pittsburgh.The # in front is the tire width, the higher the number the wider the tire will be. The next # is the tire sidewall width(referred to as tire profile). The last number listed is the wheel diameter, that will fit in the tire. Getting the same overall tire diameter can be achieved, by changing tire width and profile. Hope this helps.
<img src='
target='_blank'>
99E46 is offline
post #10 of 21 (permalink) Old 12-07-2003, 05:26 PM Thread Starter
KDM323i's Avatar
Thanks for the explanation. Yes it snows way to much, i hate snow on my car. I live near Harrisburg. So the higher the number means the bigger profile or the other way around?
KDM323i is offline
post #11 of 21 (permalink) Old 12-08-2003, 03:34 PM
ConnieLynnGus is an unknown quantity at this point
ghead
Let's say your tires sizes are 225/50 R16, here's what that means:
The first number, 225, is the width of the tire. The larger the number, the wider the tire. Generally speaking, wider tires are "stickier" and tend to provide better grip. Wider tires are better when referring to performance tires. On the other hand, if you're talking about snow tires, narrower is often considered better.
The second number, 50, represents the height of the tire off of the wheel. Again, the larger this number is, the higher the tire is. Generally speaking, higher is not better from a performance standpoint. The smaller this number is, the more "low profile" the tire is considered. These lower profile tires are considered better performing because there's less rubber between the rigid wheel and the hard pavement, thus, it's more responsive.
The last number, 16 represents the diameter of the wheel that the tire is mounted on. Generally, bigger is better here, because a larger diameter means that you're putting a greater patch of rubber on the road, which gives more grip.
ConnieLynnGus is offline
post #12 of 21 (permalink) Old 12-08-2003, 11:49 PM Thread Starter
KDM323i's Avatar
Thank you Connie for the great explanation. Thats exactly what I was looking for. My concern was the 2nd number the 50 or 55. I want a low profile tire and 50 is lower than 55. So thats what Im going with the 225/50 r16, now if I can only decide what tires to get. Thanks again...............
KDM323i is offline
post #13 of 21 (permalink) Old 12-09-2003, 01:45 AM
jaavaajoe's Avatar
jaavaajoe is an unknown quantity at this point
Just wanted to add a little clarification on the sidewall height (the second number).
225/45/17 for example. The 45 represents a percentage (or aspect ratio) of the first number (225). 225 means, 225mm wide. The 45 in this example means that the sidewall height is 45% of 225mm. So, the sidewall height in this case is 101.25 mm.
I wanted to point this out because, while the first number (the width of the tire in mm) can be compared among tires, the second number (the one you were concerned with) only makes sense when compared to the first number.
So, a 260/40/17 would have a higher sidewall height (104mm) than the 225/45/17 in our example even though the second number was lower.
To convert mm to inches, just divide. MM divided by 25.4= inches.
Hope this helps. If not, the TireRack.com has more explanations. BTW, if you are thinking about tires, I have had great success with the TireRack. Great service and prices.
Piece (yeah that kind)
Joe
<span style='color:blue'>Piece (yeah that kind)
Joe
2002 330i Titanium Silver w/ Sport-Premium</span>
jaavaajoe is offline
post #14 of 21 (permalink) Old 12-09-2003, 02:11 AM Thread Starter
KDM323i's Avatar
Im getting them at Tire Rack.... best prices ive seen. Thanks for the info!
KDM323i is offline
post #15 of 21 (permalink) Old 12-09-2003, 03:01 AM
jaavaajoe's Avatar
One recommendation since you are getting them from the Tire Rack. I am assuming that you are not buying new wheels too. So you will have to get your old tires taken off of your old rims and your new ones put on. You have probably seen that the Tire Rack has a list of local installers. Check their prices, but I would call around too.
In my experience, the installers/garages that Tire Rack recommended where much pricier than other places. To give you some idea, as I recall the recommended places were going to be about 80 dollars for all 4 tires on my old rims, and disposal of the old tires. I shopped around and found non-recommended places that would do it for around 45-50 dollars.
BTW- what type/size tires did you decide on?
Joe
Joe
545 Sport Wheels And Nitto Tires 4 Sale 98bimmerhead Wheels and Tires 1 06-07-2007 05:18 PM
Tires: Performance upgrade ///M Power M-Series (M1, M3, M5, M6) 28 11-09-2005 08:11 AM
FS: 22 inch rims and tires NEW 7on22inchs Classifieds Sell & Buy 1 09-22-2004 11:56 PM
New tires for 325i wazzubmr 3-Series (E46, E90) 2 08-10-2004 06:16 PM
