thermostat problem - BMW Forum - BimmerWerkz.com
Old 10-27-2009, 03:29 PM   #1 (permalink)
ponsford26 is on a distinguished road
thermostat problem
hi all hope someone can help
I have a 1999 328ci coupe, my lower pipe on my rad is only slightly warm, i know the thermostat is the propblem, but would this have a affect on the running of the car ie, slight engine misfire, and running rough been pluged in and its sucking in to much air, when warm you can here the air aswell, its only when its warm tho.
thanks again
ponsford26 is offline   Reply With Quote
Old 10-29-2009, 10:39 AM   #2 (permalink)
Absolutely. Is the car running hot or cold?
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 10-29-2009, 03:46 PM   #3 (permalink)
Hi there it up to normal temp but the lower rad hose dosnt seem to get at hot as the top one i noticed theres a sensor in the bottom hose
Old 10-29-2009, 10:45 PM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
If you are in the northern hemisphere and outside the tropics, weather is getting colder outside. Your thermostat will spend a longer time closed than it would in the summer months. Thus, the differential in temperature from one hose to the other will be more noticeable. If your temperature gauge is showing normal operating temperature, then everything should be okay.
Turkey Fleet Bond Holder
Thermostat STEPHEN WILKERSON 3-Series (E36) 1 06-15-2009 05:55 PM
coolant problem: (thermostat?) bimmerguy82 3-Series (E36) 5 12-05-2005 09:17 PM
Thermostat JamaC 3-Series (E36) 1 02-19-2005 05:11 PM
thermostat greg318i 3-Series (E36) 3 02-06-2004 12:43 PM
thermostat? 2slow3 3-Series (E36) 8 07-20-2003 02:06 PM
