After I warm up my car and the thermostat needle is out of the blue zone, I drive the car off and all of a sudden the thermostat needle goes all the way right to the red zone. The engine is not overheating and when I turn the car off and back on, the needle readjusts correctly. Is this just a simple malfunction or is my car trying to tell me something? Thanks!
Thanks for the plug! I'll be sure to do the same for "Warcraftjs"!
We are an emerging dot com, and one of the leading automotive distributors out there. I was just looking at your website, and thought I could talk with you about helping each of us get more exposure on the web.
We would be interesting trading website links with you. Linking to our website will benefit your site users and therefore your website. Conversely, having your website’s link on FCP Groton will give you a very high quality back-link. Sometimes called inbound links, back-links are the lifeblood of search engine positioning.
Most companies that have any sort of web presence already know about these commonplace SEO tactic. If you are interested please don’t hesitate to contact me directly at 877-634-0063 ex 204 or email me at max@fcpgroton.com
Thanks again for the plug!!
__________________ FCP Groton
877-634-0063 | info@fcpgroton.com FCP Euro - European Car Parts Specialists FCP Import - Import Replacement Car Parts
Mine did this as well. I changed out the thermostat and the problem was fixed.
If you have the time an money and you haven't done it yet, it may be a good time to change out the thermostat, waterpump, hoses and expansion tank. If and when your BMW overheats it's going to cost a lot more than replacing those parts which are a known faulty area for these cars. Good luck
UUC TSE3 | ST V1 coilovers | TMS sways | CSL replicas 18"x8.5" | ATE slotted rotors w/ Axxis USP | Clear lights all around
I'll check those out, I meant how much did the whole job cost including the thermostat, waterpump, hoses and expansion tank? I have 87000 miles on it and other than the thermostat acting up and the car has a small jerk sideways when I brake, the car is running smoothly.
I calculated the parts on Pelican and they came up to be $243. Does this sound right and can this project be done by non-mechanic or its too difficult? Thanks
Sound about right. I think that they can be done by someone that has a little experience. If you are unsure there are a lot of things on the web that can help.
Try reading this. BMW E46 - BimmerWiki
I didn't do all mine at the same time like I suggested but they all failed right around the same time. The hoses and thermostat I did myself. I have yet to replace the Expansion tank and water pump.
Once it starts warming up I'll get started on the work! Hopefully i won't have too much trouble with the tank and pump. One more thing, do I have to change the radiator hoses, or those have nothing to do with the pump and tank?
I would recomend that since you are there you should change the hoses also. Yes the radiator hoses. Like I said when you are all finished make sure that you bleed the system of air properly before you go blazing down the street. Should be the process in the link I provided to you above.
