| Use the button in the turn signal lever.By pressing the button briefly in the direction of steering column, you can call up a new function for display(time , outside temp.,etc..)To change temp. from C* TO F* and vice versa , press the right-hand reset button in the instrument cluster when the temperature display is active. |
