Temperature Guage - BMW Forum - BimmerWerkz.com
Old 01-02-2010, 06:49 PM   #1 (permalink)
Car: 2000 323i Titanium Silver
BMWer14 is on a distinguished road
Temperature Guage
I have a 2000 323i E46..this problem just started occuring. I had not run the car for over a month because of snow and cold here. But, I got it out a cople of days ago. I noticed that the temperature needle was not coming out of the blue after about 5 miles of driving....then all of a sudden it went right into the red...I pulled over, shut down the car and checked for overheating, but everything seemed normal. When I restarted the needle went back to the top edge of blue and stayed there the rest of the trip (another 15 miles), I topped up the coolant about a pint when I got home. It did the same thing today...but after I shut it down and restarted it was back to normal. Would this be a faulty temp sending unit or faulty thermostat? Or what else?
BMWer14 is offline   Reply With Quote
Old 01-02-2010, 07:42 PM   #2 (permalink)
Mr. Clean
BimmerE39's Avatar
I had something similar happen to me a few years back with my 2000 528i. It sat in the garage for nearly a month and when I finally started it I had a similar issue as to what you're describing. However, after some driving everything was fine. I thought at first I had a sticky thermostat or a bad temp sensor like you said but everything was fine. I just chalked it to the cold and the fact the car sat there for so long.
Old 01-04-2010, 09:08 AM   #3 (permalink)
JohnU's Avatar
Car: 91 750il grey and lil beat down.
JohnU is on a distinguished road
Just went thru the exact same thing. It turned out to be the connections at the temp sensor. wiggle jiggled and cleaned. works great again. Good luck.
JohnU is offline   Reply With Quote
Old 01-04-2010, 04:07 PM   #4 (permalink)
OK, I will have to give that a try...where is the sensor located?
I have noticed that if I shut down and then start up again...it fixes the problem...so, yes, it does seem to be a sensor problem.
Old 01-04-2010, 04:19 PM   #5 (permalink)
JohnU's Avatar
Not sure on your car check here: RealOEM.com Just enter your car, make, and model. It should give you a diagram that will show you where it is located.
This is a great site sent to me by another member in the forum (marti5).
Old 01-10-2010, 07:41 PM   #6 (permalink)
branman1229 is on a distinguished road
Its probably the thermostat. Mine did the same exact thing. My thermostat was stuck open. Also my expansion tank was cracked. Replaced it too.
branman1229 is offline   Reply With Quote
Guage reset spacity312 3-Series (E36) 4 12-08-2009 10:58 AM
Temperature Guage Doesnt Seem To Be Working? Denis325i 3-Series (E36) 2 10-13-2004 03:03 PM
Temperature guage not working its fcucked 5-Series (E12,E28, E34, E39, E60) 1 09-18-2004 11:25 AM
guage glass bmw_m3power 3-Series (E36) 2 02-10-2004 08:49 PM
m3 guage Chameech21 3-Series (E36) 1 11-26-2003 06:06 AM
