TEMP? - BMW Forum - BimmerWerkz.com
Old 09-01-2004, 08:16 PM   #1 (permalink)
andrew330ci is an unknown quantity at this point
Hey, my car is a 2002 330ci and my temperature is reading 150F and like 120F and rediculosly high stuff. Why is it doing this? Any ideas?
Thanks
andrew330ci is offline   Reply With Quote
Old 09-01-2004, 10:43 PM   #2 (permalink)
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
You *may* have damaged your ambient temperature sensor; although it normally reads -40°F. If you look under your front bumper, immediately in front of the driver's side tire; you should see a needle type sensor. If you dont or it looks damaged, then you need to replace it. Its a ~$40 part and is easy to install.
This is just an idea... Since your problem sounds different from the normal.
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline   Reply With Quote
Engine Temp Drops When Heater Is Turned On wulley1 3-Series (E36) 19 11-25-2007 10:55 AM
E39 Air Vents And Temp Control SKT174 5-Series (E12,E28, E34, E39, E60) 9 07-30-2007 12:06 AM
Strange Heppenings Of The Obc Temp Readout ben_t 5-Series (E12,E28, E34, E39, E60) 1 05-02-2005 07:35 AM
Turning Computer (or Temp Display) On? Superfry 3-Series (E46, E90) 1 01-11-2005 12:30 PM
oil pressure and temp sensor 325i2NV 3-Series (E36) 3 05-12-2003 02:08 AM
