Telltale light for Engine Oil lit for 15 seconds - BMW Forum - BimmerWerkz.com
Closed Thread
Old 07-16-2004, 09:52 AM   #1 (permalink)
miketang is an unknown quantity at this point
Please help! 325CI (Late 2000)
The Telltale light for Engine Oil lit 15~20 seconds after started the Engine. It lasts for 15 seconds before goes off. It happens almost every time I start the car.
Changed oil and changed 2 oil sensors. But problem is still the same. Any ideas?
Thanks in advance
miketang is offline
Old 07-16-2004, 11:41 AM   #2 (permalink)
schulman is an unknown quantity at this point
unless I really misunderstood something, isn't all of your check engine lights (including oil) come on right when you start the car, just like every car on the road? I would think it's ok for it to come on when you start the car, as long as it goes away shortly after
schulman is offline
Old 07-16-2004, 07:49 PM   #3 (permalink)
325isBaby's Avatar
Car: 2005 330xi
it's when the light remains on (perminatly) that you have problems...all dash lights go through a "self test" upon vehicle start up...if the proper signals are recieved within approx 10-15 seconds the lamp will shut off...you have nothing to worry about it sounds like.
Come see me at MySpace
325isBaby is offline
Old 07-18-2004, 11:09 AM   #4 (permalink)
yellow or red?
peterkulesza is offline
Old 07-19-2004, 10:53 AM   #5 (permalink)
The light is yellow.
The actual sequence is that after all self-test lights go off, the oil light comes on again for exactly 15 seconds.
The mechanic plugs in a reader for the error, but the fault code was "unknown".
Two sensors have been changed already but the problem is still there!! The mechanic suggested to change the third sensor which is more expensive and costly on labor. But they cannot guarantee.
miketang is offline
Old 07-25-2004, 09:38 PM   #6 (permalink)
max366 is an unknown quantity at this point
Did you solve your problem? I have exactly the same problem you describe.
what did the oil sensor replacement cost?
Thanks
max366 is offline
Old 04-26-2009, 10:34 PM   #7 (permalink)
jmiglani is on a distinguished road
Do we have any solution for above problem ? Mine 325CI/2001, also behaves the same when starting the car, it keeps the yellow check oil light for few seconds.
Thanks
jmiglani is offline
Old 04-26-2009, 11:10 PM   #8 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
This thread is five years old! Start your own threads and link to old ones, or PM the OP of the thread of interest to you instead of bumping threads that are older than your cars.
Thanks
Yellow oil light means you are one quart low. CHeck your oil level and add a quart if necessary. Otherwise, it may be your oil level sensor.
THREAD CLOSED
Turkey Fleet Bond Holder
drz is offline
Closed Thread
