system hook up - BMW Forum - BimmerWerkz.com
Old 10-12-2003, 07:50 PM   #1 (permalink)
vp209 is an unknown quantity at this point
Exclamation
Hey guys, I am planning to install a jl 12w7 and amp to my carAnd also an in-dash dvd player with 2 screens. I was wondering if it will be o.k. if I power all of it with my current battery in my car. Or should I get an extra battery to run it all through?? Or change the current battery to an optimica yellow?? I also heard if u run too much power to the vehicle , you might need to also change the alternator.
out of the blue, how often should i get an oil change?? every 3,000 miles??
vp209 is offline   Reply With Quote
Old 10-17-2003, 12:14 PM   #2 (permalink)
farbs93 is an unknown quantity at this point
A 12 W7 requires a lot of power. What amp are you running on it? If you are running a jl audio 1000/1 and that is it, you can prob get by with a optima yellow or red top (yellow is better, more Cold Cranking Amps and recharges quicker) and a good capacitator (preferably 5 to 15 farads). The alternators in BMW's are good cause bmw's come with a lot of electrical features, and the car needs a high amp altanator to run on a normal basis. Anyways... dont get an altanator till u get the other stuff installed, if it doesnt sound good, you lights dim a lot, then you will prob need to get an altanator. But i definitely recommed getting the yellow top and good Capacitator.
farbs93 is offline   Reply With Quote
Old 10-17-2003, 12:20 PM   #3 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
im running (2) xtant 1244 with a xtant x1001 (1000x1 watt) amp. also with an alpine headunit and the battery is doing fine. its only when i listen to music at a constant high volume when i can sense the battery being drained. (when headlights flicker). i dont think an extra battery is a good idea, but a good capacitor is the way to go.
oil changed depends; i use a synthetic oil which usual gets changed every 15,000 miles
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 10-18-2003, 12:55 PM   #4 (permalink)
DHW BMW328I's Avatar
DHW BMW328I is an unknown quantity at this point
I was planning on adding an in dash dvd player to my e46, with to in the head rest, where are you going to put your 2nd monitor ?
DHW BMW328I is offline   Reply With Quote
Old 10-18-2003, 08:20 PM   #5 (permalink)
i second the capacitor idea. i think crutchfield has some for a decent price.
peter
Old 10-21-2003, 10:47 PM   #6 (permalink)
thanx guys, i just installed my system and i didnt use an xtra battery. i got a capacitor though. Its powered by a jl 500/1 amp. Sounds real nice .
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
2001 Bmw 325xi Audio System BMW325xi 3-Series (E46, E90) 5 03-28-2005 06:19 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
New technology coming to 2005 Infiniti models AZ325Ci Other Rides 4 06-13-2004 09:14 PM
