Synthetic Oil - BMW Forum - BimmerWerkz.com
Old 01-23-2004, 09:12 AM   #1 (permalink)
KDM323i's Avatar
KDM323i is an unknown quantity at this point
Does everyone use synthetic oil?
My other love besides my bimmer is my Harley !!!!!!!!!!
KDM323i is offline   Reply With Quote
Old 01-23-2004, 09:47 AM   #2 (permalink)
bmrbum is an unknown quantity at this point
could i just ask a question also connected to the above my 2004 325i has the synthetic oil as above and the dealer told me that it is good for 15000 miles. never used synthetic before it scares the crap out of me to drive that far between changes would appreciate input from users of same thanks guys.
bmrbum is offline   Reply With Quote
Old 01-23-2004, 10:09 AM   #3 (permalink)
BMWL2's Avatar
BMWL2 is an unknown quantity at this point
Send a message via AIM to BMWL2
I use mobil 1 synthetic.
I dont think it is a good idea for you to go 15000 between changes either. I have only seen some that claim their oil is good for 4000 miles and I personally wouldnt do that either. Mine gets it every 2500-3000, period.
Motovated Motorsport Forums
http://www.motovatedcc.com
BMWL2 is offline   Reply With Quote
Old 01-23-2004, 10:17 AM   #4 (permalink)
KDM323i's Avatar
Is it recomended by BMW to use synthetic? I just got mine changed and had them put synthetic in, Mobil 1. I do mine every 5000.
Old 01-23-2004, 11:01 AM   #5 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
Once a year for me I use it Mobil 1. ie thats if you do it yourself spend 50 dollars for oil and filter . Most car manufacturs are increaseing there oil change intervals from 3k to 5k or more. One example is my family owns a 98 ford explorer w/v8 motor oil change interval is 5k with conventional oil . I was a little reluctant at first two when i saw the intervals on bimmers but i freqently check the oil and make sure it is not low and for one year or about 10k on my computer i have not added any oil. You might as well put conventional oil in if you are going to change every 3k 5k miles. thats my opinion you are just wasting your money.Synthetic when its designed for extreme conditions. . Check and replace once a year is what i do and have not had any problems.
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 01-25-2004, 12:05 AM   #6 (permalink)
AZ325Ci is on a distinguished road
BMW recommends using only synthetic oil. However, you can go 15000 miles between oil changes. That's what I'm doing, but I change my oil filter every 7500 miles.
AZ325Ci is offline   Reply With Quote
Old 01-25-2004, 10:56 AM   #7 (permalink)
TECH's Avatar
The 15k service intervals for the newer cars REQUIRES synthetic oil. Regular oil shouldn't be run that long.
what engine oil to put in because i dont know if its syntec or normal? träumer 3-Series (E21, E30) 3 11-01-2005 02:40 PM
Synthetic or regular oil? am4tide 3-Series (E36) 6 07-14-2004 08:03 AM
