sunroof visor??????? - BMW Forum - BimmerWerkz.com
Old 07-03-2006, 07:04 PM   #1 (permalink)
speedybmw's Avatar
Car: 2003 BMW 330xi
speedybmw is on a distinguished road
the visor beneath my sunroof wont fully close(theres about an inch gap) and was wondering if there is a quick fix for this or does a mechanic have to do it.
what is the problem and what could i do. i have a 2003 330xi.
speedybmw is offline   Reply With Quote
Old 07-03-2006, 11:58 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
If the sunroof lid is in "tilt" mode then the sliding headliner will not close completely. If the sunroof is closed but the headliner still will not go all the way forward then it is most likely that the sliders on the headliner have broken and are causing it to jam. This is common on e46 sunroofs.
Here is a link to a DIY writeup I found doing a google search.
http://www.jumboprawn.net/jesse/proj...oof/index.html
Also if you look at the writeup in the second picture down the gray drive which is labeled (A) is outdated and often times bends or breaks. If you have that style then it is recommended that you upgrade to the newer style design but this would be a much bigger job. If you dont want to upgrade then at least be sure that the piece is not bent and contacts the sliders well and does not allow the sliders to go under it, otherwise this will cause them to break again soon.
Good Luck,
DT
Auto open/close sunroof problem QuieroFU 3-Series (E46, E90) 8 03-29-2006 03:29 PM
HELP!! Sunroof Leak, Need Gasket slyhog-22056 1,6,7,8 - Series and Mini Cooper 1 03-22-2006 05:31 PM
My Sunroof..... breezd 3-Series (E36) 4 04-15-2005 10:03 PM
Sunroof Noises Caused By Vibration. victorgallas 3-Series (E36) 0 01-20-2005 03:27 PM
sunroof problem? help!!! pherbolario 5-Series (E12,E28, E34, E39, E60) 4 12-30-2004 05:57 AM
