Hi Guys, I have a 99 328i, When I use the one touch button to close the sunroof, sometime it close all the way & sometimes it goes half way then stop in the middle.
If I hold the button it will close. Am I using the one touch button wrong ? How wrong can you use a one touch button ? :banghead
Originally posted by DHW BMW328I@Sep 5 2003, 10:24 PM Hi Guys, I have a 99 328i, When I use the one touch button to close the sunroof, sometime it close all the way & sometimes it goes half way then stop in the middle.
Thanks Guys, doesn't make it ok but hey at least I know i'm not the only one, I didn't really want to take it to the dealer for a problem that is not a true problem.
Hi everyone,I'm new and I'm from Rome(Italy).
Had the same problem with my roof to.If you keep the button pressed down for over 15 seconds you will reset it and then you'll be fine.If that doesn't fix the probem then perhaps the internal cover is broken(the one you cal pull closed by hand).If you look at it from the out side with the roof open check if the four clips aren't broken.
Bye and hope I helped. :gulp
The holding for 15 seconds didnt correct my problem...
Im too worried about it though...
Related Threads
BMW Werkz
668.8K posts
97.6K members
Since 2003
