Sun Roof Off Track - BMW Forum - BimmerWerkz.com
Old 07-23-2005, 08:14 PM   #1 (permalink)
FL325i is an unknown quantity at this point
2003 325i. Had it 2 weeks and the sun roof started making this awful noise when we tried to open it today. A couple of attempts to close it and it apparently popped back on the track and shut. Seems to be OK now. Is this a common problem? It's going into the shop next week because the antenna wasn't hooked up to the stock radio when the previous owner's aftermarket sound system was removed, so I'll also present it to the dealer. We have CPO warranty until 50K...
Thanks for any replies!!
Also, do you guys check any other boards?
FL325i is offline   Reply With Quote
Old 07-23-2005, 08:25 PM   #2 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
yes it is a very common problem..but an easy fix
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 07-23-2005, 09:04 PM   #3 (permalink)
Do you mean just popping it back on track? Or will it eventually get to the point where I need to change out the track, like a window regulator?
Thanks for replying!
Old 07-24-2005, 03:54 PM   #4 (permalink)
im pretty sure it is the sunroof clips that are broken. (it also could be your window regulator)
the sunroof shade first gets off track and if lucky, it will go back and stay okay.
if not, the clips will break. these clips are found on either side of the sunshade.
you will need to replace the clips and get the sunshade on track.
_____
it could be your window regulator that is making the noises, or it could be the sunshade/clips.
you should look along the sunroof track to see if there are anything blocking it...or perhaps some evidence of broken clips.
Old 07-24-2005, 11:00 PM   #5 (permalink)
Thanks! It's going to the dealer tomorrow. I'll make sure they check it.
Old 07-26-2005, 02:00 AM   #6 (permalink)
Well, the dealer found nothing wrong. I'll have to take a peak myself...
Leaking Cabriolet roof boomer2005 3-Series (E21, E30) 3 11-18-2005 03:25 PM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
Replacing til crank on my manual sun roof.. Lien 3-Series (E36) 3 08-23-2004 10:04 AM
E30 electric convertible roof will not lock ijahn2000 3-Series (E21, E30) 0 05-04-2004 08:25 AM
Open Invitation for a Track Day at Pocono Juryjt North East 2 04-23-2004 03:54 PM
