Stock Brake Guide Pin Upgrade - BMW Forum - BimmerWerkz.com
Old 06-22-2005, 11:57 AM   #1 (permalink)
Car: 2005 545i Sport, Nav, HUD, CWP
top6491 is an unknown quantity at this point
Anyone ever ugrade the stock rubber guide pins and bushings with machined metal ones? I was just wondering if it is an ok job to perform and if they made a noticable difference in brake feel or pad wear. Thanks...
top6491 is offline   Reply With Quote
Old 06-22-2005, 02:13 PM   #2 (permalink)
zibby's Avatar
Car: yes
[snapback]355893[/snapback]
Never play with the original brake components or hardware ! you can instal after market pads or rotors, whatever you like , but do not mess with something related to direct safety ! BTW I think the metal one wiil make your brake noisy, you do not want that !
http://www.q8oils.it/
Old 06-22-2005, 03:29 PM   #3 (permalink)
it's a good upgrade. A friend of mine installed them on his front brakes after he switched to zimmerman rotors and axxis ultimate pads. That was about a year ago, and he's had no problems since.
ignore zibby, these are safe and are recommended by BavAuto.
Old 06-22-2005, 07:09 PM   #4 (permalink)
i agree that this part is safe to replace, no big deal.
in a relatively new car it likely will make no difference. this is something that makes sense in e30....
Old 06-23-2005, 09:19 AM   #5 (permalink)
I had him take a wheel off the front and flip back the caliper to check out the pads. They were both worn nice and flat. When we changed out his stock pads, we noticed that the inside edge was wearing faster than the top edge. Problem solved!
E30 Brake Upgrade E30_australia 3-Series (E21, E30) 9 02-10-2005 07:35 PM
Big brake upgrade for E28s Philo 5-Series (E12,E28, E34, E39, E60) 1 05-04-2004 12:29 PM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
