Steering Wheel noise on 323i 1999 - BMW Forum - BimmerWerkz.com
Old 06-23-2006, 09:16 PM   #1 (permalink)
Car: 1999 BMW 323i
LatinGod is on a distinguished road
Smile Steering Wheel noise on 323i 1999
Ok, I just got this car as a gift from a friend, and it has been working great, however this morning the steering wheel is making noise, like in a not enough steering wheel fluid kind of noise....wanted to check if this is normal on these cars, and whats the best way to approach it...just put more steering fluid in it and then take it to a shop?? Which fluid is the recommended one for my car??
LatinGod is offline   Reply With Quote
Old 06-24-2006, 10:31 AM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Check your fluid level add as needed (use ATF)...it is really common on BMWs for the powersteering hoses to leak so have it checked out
Come see me at MySpace
Old 06-24-2006, 12:16 PM   #3 (permalink)
Car: 1999 BMW 323i
Thanks for your help...Where would I have to check it?? Sorry I'm not to motor familiar, I can see the ATF Fluid cap, The Oil Cap, the Brakes Fluid Cap, But I cannot seem to find the Steering wheel fluid cap....
Old 06-25-2006, 01:47 PM   #4 (permalink)
441tech's Avatar
441tech is on a distinguished road
The cap that says "ATF" IS the power steering fluid reservoir. Unscrew that cap and there will be a low and a high mark indicating the level. There is no place to check the Auto. trans. fluid, other than a hole on the side of the transmission towards the back.
I just ordered all new lines and a pump for my car, 'cause the idiot before me let the pump go dry and ruined it. Fortunately I found a low-mileage pump for $100 online. The dealers get about $450-$500.
My advice is that if it is making noise, the fluid is low, and correct the problem before you trash the pump.
441tech
Officer: "I see you set the table for four."
Groucho Marx: "That's nothing--I set my alarm clock for eight."
441tech is offline   Reply With Quote
Old 06-25-2006, 02:05 PM   #5 (permalink)
Car: 1999 BMW 323i
Thansk Mate...any recommendations on the ATF Fluid??
Old 06-25-2006, 02:56 PM   #6 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Dex III
noise in steering wheel ksee777 3-Series (E36) 9 04-29-2006 10:43 PM
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Noise Brodees 3-Series (E46, E90) 3 03-03-2005 09:10 AM
