Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 02-10-2004, 01:42 PM   #1 (permalink)
Silver4evr's Avatar
Photos: 0
If there is a previous post to this topic, please point me to it.
If not, what's the best method to get rid of that damn squeak! My buddy is fed up with it.
Old 02-11-2004, 11:08 AM   #2 (permalink)
Photos: 0
new stock pads, pad adhesive liberally applied to the back of the pad. short of this, not much will work.
peter
Old 02-11-2004, 07:51 PM   #3 (permalink)
Silver4evr's Avatar
Photos: 0
Thanks!
Old 02-21-2004, 04:16 PM   #4 (permalink)
TECH's Avatar
Photos: 0
You should be able to get Jurid brand pads from the dealership. The ones that are more prone to squeek are the Textar pads. If you don't specify, you'll get Textar.
If the rotors are worn, as in having a deep ridge on the edge, then that can aid in the noise.
Old 02-21-2004, 11:17 PM   #5 (permalink)
EXtech's Avatar
Photos: 0
Go buy some of 3M's copper colored anti-seize/lubricant. It's in a white metal can. Wire brush the dust build up from the caliper/pad mounting points. Coat the back of the pads and the ends that touch the caliper with this stuff. It'll never squeak again. I have used that miracle stuff on EVERY brake job I have ever done and never a chirp. I used to average 5-10 BMW brake jobs a week and NEVER had one come back. When the X5 came out there were many complaints about intermittent squeaking. Nobody knew exactly why. I'd put some of this stuff on there and it went away. problem solved. Swear by that sh**
Now, do not get this confused with a constant squeal or grinding. This is usually indicative of worn pads/rotors or severe dust accumulation or other debris.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 02-22-2004, 12:02 PM   #6 (permalink)
Silver4evr's Avatar
Photos: 0
good answer!
Thanks extech
vB code is On
Squeky Brakes ynotony 3-Series (E36) 2 07-21-2005 07:07 PM
Squeeling New Brakes Ljk619 3-Series (E46, E90) 6 07-08-2005 02:31 PM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 12:02 PM
do your brakes squeak? GnarlyCow 3-Series (E46, E90) 12 09-22-2004 09:03 PM
Smoking brakes? Pegasus 3-Series (E36) 21 09-16-2004 05:30 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
