Shimmy in wheel... - BMW Forum - BimmerWerkz.com
Old 04-03-2010, 09:44 PM   #1 (permalink)
hookman66 is on a distinguished road
Shimmy in wheel...
My '99 328i has a intermittent shimmy in wheel.I just had the conrtol arms replaced.Steering wheel shimmies,then noticed passenger front wheel extremely hot.Is it a sticky caliper?Any other ideas?What is a good rebuilt caliper?Also,any reccomendations on brake pads?Where to order these parts from?Is it a easy DIY to change out cliper?Please help...
hookman66 is offline   Reply With Quote
Old 04-03-2010, 09:55 PM   #2 (permalink)
That right front brake needs service right away. All the brakes may as well be serviced at the same time.
Old 04-04-2010, 07:19 AM   #3 (permalink)
Im thinking its the passenger side caliper.I had my fluid changed and my mechanic said the calipers were ok,just need to watch them.It only shimmies like once a week.Should I just change them out?Who sells good remanufactured?
Old 04-04-2010, 10:46 AM   #4 (permalink)
Mr. Clean
BimmerE39's Avatar
If the brake caliper is sticking chances are you're going to need to rebuild the caliper by replacing the piston. This is a fairly easy task and you can buy the rebuild kit through Turner Motorsport.
If you're not looking to add braking performance to your brakes stick with standard pads and rotors. On the other hand, if you would like to add some performance look into slotted rotors and ceramic pads. There's really an infinite amount of combinations when it comes to rotor/pads.
Old 04-04-2010, 06:29 PM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
all the above considered... OR, a bad wheel bearing causing the rotor to wobble.
The wobble will cause the shimmy you feel; and,
The wobble will cause friction on different parts of the rotor, thus, the heat as complained of.
Take note though.... if the shimmy is felt only on braking, then it is the rotors, that are warped.
Old 05-03-2010, 10:57 PM   #6 (permalink)
dcuse32's Avatar
dcuse32 is on a distinguished road
Shaking is caused by bad tie rods. could be inner or outer.
dcuse32 is offline   Reply With Quote
Wheel Shimmy/Wobble 86red325es 3-Series (E21, E30) 26 07-08-2009 09:57 PM
Front Wheel Shimmy brians15 5-Series (E12,E28, E34, E39, E60) 6 03-12-2005 04:44 PM
Shimmy? masshoff 3-Series (E46, E90) 7 02-09-2005 12:49 PM
Steering Wheel Shimmy At High Speed Braking Quickman59 3-Series (E36) 12 10-05-2004 12:52 PM
NEW brake shimmy nosuchsol 3-Series (E46, E90) 4 08-16-2003 08:50 PM
