Shifting Into Reverse Hard - BMW Forum - BimmerWerkz.com
Old 03-06-2005, 07:24 PM   #1 (permalink)
2000BMW323i is an unknown quantity at this point
Most of the time before like in the morning or after my car has been sitting for a while. When I go and try and put it in Reverse to back out, it is very hard and I have to kind of force it into gear. Is that because the car is not warmed up or is it something else
2000BMW323i is offline   Reply With Quote
Old 03-07-2005, 07:27 PM   #2 (permalink)
zibby's Avatar
Car: yes
Hi ! is your car equiped with a GM 5 TIPRRONIC transmission ? if yes be cerfull ,this trannys are simply "P of S'. Men I do not want to freak you out ,but expect that one day you will loose reverse gear ( broken drum ) and it wiil cost you big $$$$$$, thats common problem on this cars with GM 5 -TIPTRONIC, looks like you already have a small crack on the drum inside the tranny. Main cause of that- shifting from reverse to drive while car is still moving or from drive to reverse in the same situation- NEVER DO THIS ,PLEASE !!!, always stop car completly. Best regards.
http://www.q8oils.it/
Old 03-08-2005, 12:32 PM   #3 (permalink)
I have a 5-speed
Old 03-08-2005, 12:37 PM   #4 (permalink)
Ci Baller is an unknown quantity at this point
Originally posted by 2000BMW323i@Mar 8 2005, 01:32 PM
I have a 5-speed
[snapback]306464[/snapback]
I have experienced the same thing. My car is currently in the shop ghead
canshaft sensor went bad... But I will mention this problem to them as well, and I will let you know what they say.
Ci Baller is offline   Reply With Quote
Old 03-08-2005, 02:41 PM   #5 (permalink)
jkloese's Avatar
jkloese is an unknown quantity at this point
After you start the car, try letting the clutch out while your in neutral first, that will get the gears spinning, then try to put the car in reverse. Sometimes the gears will not be lined up and since the car is first started and hasnt been moved, none of the gears inside are spinning and will not line up properly. I wouldnt force it into gear because you can damage the syncro's. Let us know what you find out.
<img src='http://www.bmw-forums.com/forum/index.php?act=Attach&amp;type=post&amp;id=18826.jp g' border='0' alt='user posted image' />
jkloese is offline   Reply With Quote
Old 03-08-2005, 06:12 PM   #6 (permalink)
zibby's Avatar
Car: yes
I have a 5-speed
Issue with a broken drum and complet stoping before you engage any gear , apply only to 5 speed auto transmission , not a manual.
Old 03-08-2005, 07:05 PM   #7 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
it just needs to get warmed up.
when its cold out, i always do the following:
clutch in
put into 2nd
then immediatly into 1st
then reverse. and at this point, reverse should be pretty smooth
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
No Reverse bad man working 1,6,7,8 - Series and Mini Cooper 5 09-11-2005 11:53 AM
Shifting Kinda Hard whitey_E30 3-Series (E21, E30) 1 08-21-2005 06:45 PM
Clutch not angaging on reverse gear! 4tunesfool 3-Series (E46, E90) 7 09-17-2004 08:41 AM
No clutch engagement in Reverse? 4tunesfool 3-Series (E36) 3 09-05-2004 06:37 AM
