Shifting On A 325i Auto W/ Step - BMW Forum - BimmerWerkz.com
Old 12-28-2004, 01:04 AM   #1 (permalink)
Neo_Skyline is an unknown quantity at this point
Hey everybody, I just bought a new 325i. Needless to say, I'm more than excited and extremely happy.
Unfortunately, I couldn't get a manual so I have the automatic w/ steptronic. I love the sports mode. The handling is so freaking tight. Anyways, my question is about the "manual". Is it harder on the engines? How should I step up and down? It seems to spin at an overall higher rpm. Also, in accelerating from a stop, should I 'ease' the pedal in, or should I just press it hard from the start? I'm kind of going in between, and it jerks forward slightly.
So I've been reading some of the other threads, and it seems like a cool forum. Glad to be a part of it all B)
Neo_Skyline is offline   Reply With Quote
Old 12-28-2004, 07:01 AM   #2 (permalink)
congrats.
1. do not stress it in the first 1500 miles, no matter what. i'd not exceed 4 krpm, tends to score the cylinders...or gets the rings stuck...could be bad scene.
2. once broken in press the right pedal, acclerate like a bat out of hell, the car will bounce at the rev limiter. you will feel it. that means you've gone too far and needed shifting , then adjust your driving style.
DO NOT ATTEMPT TO MANUALLY DOWNSHIFT BEFORE YOU GET THE FEEL OF THE REVS VERSUS SPEED.
3. accelerating from the start is as you please in terms of peeling off or being gentle.
Old 12-30-2004, 04:29 AM   #3 (permalink)
PMB
PMB's Avatar
PMB is an unknown quantity at this point
I test drove one a while ago and the transmission will not let you shift down if the revs are too high, it will override you. Similarly if you floor it and try to manually shift up early it will override you if it thinks it can do better.
Once run in just floor it. The electronics and diff will take care of the rest. You need to put your trust in it. It will not fail you (unless you switch the electronics off which is also good for a laugh),
PMB is offline   Reply With Quote
Old 12-30-2004, 09:30 AM   #4 (permalink)
SonTon2003 is an unknown quantity at this point
it won't let you shift if the revs will be too high or the trans.
SonTon2003 is offline   Reply With Quote
1986 325i auto vet-racer 3-Series (E21, E30) 1 11-08-2005 07:20 PM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
325I, Auto, bogus-down Rolm 3-Series (E36) 1 08-21-2004 10:47 PM
