Shaking steering wheel when hit bumps turning Left
Hello can anyone help me on this, my car when i am driving straight it is fine but when i am switching lanes to the left lane and i hit a bump on the road my steering wheel starts to shake like crazy well as does the car, then when i straighten the wheel out it stops. Idk what the issue is i have looked under my car and cant seem to find this issue can anyone help me if they got the answer for me. Also its a 2000 bmw 323ci 2 door coupe. Stock wheels and tire size.
I've got to suggest suspension bushes at this stage...
Lift the front onto axle-stands then have a good tug around the linkages/control arms to see if there is any play...
Get back to us with results buddy.
__________________ Eso es todo! Please press the "REP" button if you are happy with your response/answer...
Please JOIN, or just have a look... Its Totally FREE... BMW Part Market
Well the controll arm seems to be what is causing the issue, they seem lose and when i drive and hit a little bump i could hear some kind of play under the car I look to see if i could tighten the one bolt on the control arm but i cant seems to already be tight. That is if we are talking about the same thing. Its the bar that almost looks like a C and has in the midde of where it curvs a bolt that goes up i think into the frame with a long bolt. Well from that area it seems to be all lose but bolt will not tighten anymore and its actually dangerous to be driving it like that but it my old car right now.
I agree. This sounds like CABs. You may also consider changing the rear trailing arm bushings (most definitely if the rear feels loose as well), since you'll need to get an alignment anyways.
It's not too bad if you have the right tools. A quick google search will yield a few DIYs. However, I am right now debating whether I want to do myself (m car needs it too) or simply have a shop do it, mostly because I don't want to mess with it.
Also, you may need to change out the control arms as well as the bushings if the ball joints are worn (f I remember correctly, the ball joints are integral to the control arm).
