Service Soon Engine Light - BMW Forum - BimmerWerkz.com
Old 01-18-2005, 12:00 PM   #1 (permalink)
caldoone is an unknown quantity at this point
Hi
I have my new 325i for 6 months now. Today in this cold weather of -30, the Service Engine Soon Light came on. It stayed on for about 10 mins after which it stopped.
Is this something normal to happen in this cold weather? Something i should worry about?
Thanks a lot.
caldoone is offline   Reply With Quote
Old 01-18-2005, 12:36 PM   #2 (permalink)
EnvyM3's Avatar
EnvyM3 is an unknown quantity at this point
Send a message via Yahoo to EnvyM3
Originally posted by caldoone@Jan 18 2005, 12:00 PM
Hi
Thanks a lot.
[snapback]274051[/snapback]
You may want to get it checked out. My car is 4 years old and it does not happen. It was also -20 with the wind chill here this morning.
<img src='http://www.european-forums.com/forums/uploads/post-1-1119565837.jpg' border='0' alt='user posted image' />
EnvyM3 is offline   Reply With Quote
Old 01-18-2005, 12:59 PM   #3 (permalink)
///Matt's Avatar
Go to autozone (or equiv.) and get the code read. It could save you $ in the long run....a check engine light now could mean something later....
Old 01-31-2005, 08:15 PM   #4 (permalink)
9inarow's Avatar
9inarow is an unknown quantity at this point
My wife's 03 325i has been back to the dealer 3 times for the freakin' Service Engine Soon light. It's back on again.
This is turning into a pain in the neck. She's gonna set an appointment with the dealer to have it checked out and have her first oil change ... it's been 18 months. You think she listens to me when I tell her to have the oil changed no later than 12 months ???
9inarow is offline   Reply With Quote
Old 02-04-2005, 08:07 AM   #5 (permalink)
njtech is an unknown quantity at this point
Hi
Thanks a lot.
Since it's only 6 monrths old, I would have it checked buy the dealer. And because it was so cold... I would lean towards the the converter not heating up fast enough and setting a fault code which would trigger the light, the the ecm turns it off after it sees the proper signal.
HTH
Steve
njtech is offline   Reply With Quote
Old 02-04-2005, 03:11 PM   #6 (permalink)
Hi
I just went to the dealer to see what was the thing with the SEC light and they found out that some of the ignition coils were not working properly, which was causing the engine to misfire, and hence causing the service engine light to come up.
Therefore I would take your SEC lights to be on seriously enough and not just rely on it being just a result of cold phenomenon. It could be more serious than that.
check engine light Kubna 5-Series (E12,E28, E34, E39, E60) 7 06-28-2004 02:00 AM
Check engine light Necktie 3-Series (E46, E90) 3 06-26-2004 01:54 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
