Service Indicator Reset??? - BMW Forum - BimmerWerkz.com
Old 11-22-2004, 02:05 PM   #1 (permalink)
djm260 is an unknown quantity at this point
I just had my 1999 328i serviced. How do I reset the service indicator which shows "-800" when I start the car. Is there a way to do it outside of taking it to a BMW dealership? Thanks.
djm260 is offline   Reply With Quote
Old 11-23-2004, 07:42 AM   #2 (permalink)
badpatten is an unknown quantity at this point
[snapback]235347[/snapback]
If the place you took it to, was a certified BMW service dealer they should be able to do it. I know the place I am taking mine too today does it. My service should be only $150
badpatten is offline   Reply With Quote
Old 11-24-2004, 09:35 PM   #3 (permalink)
I just had my 1999 328i serviced.* How do I reset the service indicator which shows "-800" when I start the car.* Is there a way to do it outside of taking it to a BMW dealership?* Thanks.
I figured it out for the service center. Put the key in the ignition, hold the trip meter counter (left side) for 5 seconds, then turn the key to the 1 position while keeping the trip meter pressed until the display starts to flash reset, once that happens let go of the trip reset and press it again. This should reset the meter. Hope it works for you, it did for me.
Old 11-25-2004, 11:37 AM   #4 (permalink)
boaz is an unknown quantity at this point
you can conenect hole number 7 and 19 for 11.7 sec its in your computer conector
if you standig facing the car under the hood on the left
boaz is offline   Reply With Quote
Old 11-29-2004, 01:28 PM   #5 (permalink)
Thanks.
I tried to press the trip reset, then turn to position 1. Now, instead of a -800 number, I get "OIL SERVICE 15,000" along with soome annoying beeps.
Any advice??? Thanks!!!
Old 11-30-2004, 08:33 PM   #6 (permalink)
69Mach1351c is an unknown quantity at this point
put your seat belt on, press the trip button and turn to position 1, when reset shows up let go and hold again till reset blinks, let go and press trip button once.
enjoy....
69Mach1351c is offline   Reply With Quote
Just Got My Baby... What Service To Do??? Guernica 3-Series (E36) 11 04-03-2005 09:07 PM
Should I Get It?! Cellardoor M-Series (M1, M3, M5, M6) 4 02-05-2005 03:19 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
