Secondary Air System Flow - BMW Forum - BimmerWerkz.com
Old 03-07-2005, 07:32 PM   #1 (permalink)
nrana99 is an unknown quantity at this point
Hello,
My check engine light came up while I was driving. Checked with R5/FCX code reader and found out code F6 which is "Secondary air system flow too low, Cyl #4-6" Does anyone what it means? What should I do to get it fixed? Do I need a new air filer or something?
Thanks,
Luke
nrana99 is offline   Reply With Quote
Old 03-07-2005, 08:01 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
it's the secondary air system (emissions related item) I would take it to the dealer and let them check the system and it's related componants.
Come see me at MySpace
Old 03-10-2005, 02:43 PM   #3 (permalink)
Hootie361 is an unknown quantity at this point
Send a message via AIM to Hootie361
I have the same error right now. I'm replacing my intake air filter this weekend. If that solves it, I'll let you know.
Your Lane ------>
Hootie361 is offline   Reply With Quote
Old 03-10-2005, 07:46 PM   #4 (permalink)
it won't. it has nothing to do with the air going through the intake.
it is probablly the actual pump that is faultl or the valve on the engine. defiantly take it to the dealer they can do tests through the computer that can pin point what is broke.
not that changing the air filter is a bad thing but it will have no effect on the check engine light if it is for the secondary air system.
Old 03-14-2005, 10:00 AM   #5 (permalink)
good call, changing the intake had null effect. what pump and what valves specifically would have this effect? I'd like to look the parts up in my Bentley manual and see if it's worth just doing the work myself. Nothing like taking the car to a dealership and having them charge you $100 to tell you they need to over-charge you on parts and labor for something that could have been done in my own garage, ya know?
Your Lane ------>
Old 03-14-2005, 05:39 PM   #6 (permalink)
the pump is a black round lookin' think on the exhasut side of the engine bay. there is a valve that mounts on the engine. it has a vacume line going to it and is a silver color it is on the front of the engine on the exhaust side. the valve is pretty easy to change, but the pump can be tricky i can't recall if some 5 series or if some 3 series have the pump mounted behind the right front wheel well covering. if it is behind the wheel well covering those are a pain even when you do them on a lift in a dealership
and i'd take it to the dealer. even though you pay more you get what you pay for. they have all the knowledge and the tools to make sure it is done right. not saying that you woulnd't or an independent shop wouldn't but they would be able to tell if it is a air pump or the valve. and why pay more for parts you don't need. you could atleast take it in and have them diagnose it for you.
Old 03-22-2005, 08:47 AM   #7 (permalink)
Thanks for the help. My Bentley manual doesn't seem to have the secondary air pump listed... hmph.
So far it hasn't affected my car's performance. Come time for emissions inspections, I'll find out if it hurts then. If it does, I'll fix it, if not I can live without it.
And I'll only take my car to the dealer to let them work on "non-bolt-on" procedures. Replacing a pump or a valve doesn't get much easier. Well, spark plugs or an air filter maybe... but you get the idea.
Your Lane ------>
Old 03-22-2005, 09:12 AM   #8 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
K... just so you know.. that code you had read is a code which can and will be caused by many different variable failures. I'm not saying its the said valve... but I've had this code in many peoples car plainly be just a O2 sensor bad... which tells the computer that its not getting enough exhaust out... common problem.. get it looked at the dealer... you should be within coverage... hopefully...
And good luck,
Les
1997 E36 M3 1990 E30 325i
Old 03-22-2005, 09:12 AM   #9 (permalink)
The Deuce is an unknown quantity at this point
If it is a component related to your emissions, the feds require a longer warranty than the standard drivetrain.
I'm assuming your car is a '99, and would most likely be out of warranty on that anyway, but its worth a shot.
Emissions stuff is real finkey anyway, I hate messing with that crap.
2002 BMW 530i
1997 Ford Mustang GT
1995 Honda VFR 750 (For Sale)
1964.5 Ford Mustang
The Deuce is offline   Reply With Quote
Secondary Air System Flow Too Low eric 5-Series (E12,E28, E34, E39, E60) 2 03-23-2005 02:23 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
secondary air system flow to low 1st Beemer 3-Series (E36) 0 03-25-2004 07:17 AM
