Screeching Noise When Turning Right E46 330 - BMW Forum - BimmerWerkz.com
Old 02-28-2005, 09:08 AM   #1 (permalink)
warren's Avatar
warren is an unknown quantity at this point
I get a loud screeching (sounds similar to a belt slipping) when I turn my steering right, it appears to be coming from the rack or that area. My fluid reserve is full and I'm confused why it only happens when I turn right?
Would the control arm bush failure cause this?
330ci 2001 61K miles
Many thanks for any help,
warren
warren is offline   Reply With Quote
Old 02-28-2005, 05:04 PM   #2 (permalink)
jisang1's Avatar
jisang1 is an unknown quantity at this point
see my question about a wheel bearing failure.....if your left bearing has failed, then your car will make a humming noise when you turn right....(and vice versa)... If the noise GOES away when you turn LEFT, that means your right bearing is OK, but your left one is causing the trouble...
test it by driving in a straight line and then turning left then right....
The parts for such a repair (if it IS indeed the wheel bearing) will run approx $125. Labor may be DIY or a mechanic - your choice.
jisang1 is offline   Reply With Quote
Old 02-28-2005, 05:13 PM   #3 (permalink)
jisang1's Avatar
BTW, the noise gets progressively lounder if the problem is left unchecked....if it is REALLY loud, its possible that your bearing is in really bad shape...
Although it SOUNDS like a bearing problem, It is also possible that the problem is NOT your bearing, so I would get it checked out if I were you....
Old 03-03-2005, 09:16 AM   #4 (permalink)
Howie's Avatar
Howie is an unknown quantity at this point
I know it sounds stupid, but its not the tyre rubbing on some loose plastic trim from inside the wheel arch is it?
Howie is offline   Reply With Quote
Old 03-03-2005, 09:26 AM   #5 (permalink)
warren's Avatar
Problem solved!
It's the track control arm (Wishbone Joint). I have seen this mentioned a few times as a weakness on the E46 2001 and BMW have modified the replacement part. The bad news is the price £612.61 fitted!
Old 03-03-2005, 10:06 AM   #6 (permalink)
Howie's Avatar
Ouch... That is not cheap.
Old 03-03-2005, 10:16 AM   #7 (permalink)
warren's Avatar
price is for both sides, but still not great for an item that is suspect from new. My car has done 61K miles.
Some Rattling Noise In 735il When Turning crackerjack 1,6,7,8 - Series and Mini Cooper 0 08-28-2005 02:22 PM
Screeching Noise Under Hood fdeee 5-Series (E12,E28, E34, E39, E60) 3 06-01-2005 12:13 PM
Noise While Turning drz 3-Series (E36) 6 02-17-2005 11:48 PM
Turning Wheels Makes Weird Noise LivinFast67 3-Series (E36) 4 10-01-2004 07:34 PM
Scary Screeching noise Nadsam 3-Series (E36) 3 05-21-2004 04:51 PM
