Savage Coolant leak - BMW Forum - BimmerWerkz.com
Old 03-06-2012, 08:34 PM   #1 (permalink)
AUS 320I E90 is on a distinguished road
Savage Coolant leak
I am new this, sorry for being ignorant,
My 2005 320I E90 has sprung a worriyng leak (it ran close to dry) I filled it up the next morning, drove to work. I went and check the car an hour or so later and there was a patch of water the size of the car and it must have been dry (took 4L to re-fill) drove it home got a low water light just before I got home.
I cant directly see where the leak is but it seems (standing in front of the car) to be coming from the bottom right side of where the radiator is.
Also, it seems to start leaking as soon as I put coolant in.
Dose that sound like cracked hose or a more serious problem?
AUS 320I E90 is offline   Reply With Quote
Old 03-07-2012, 03:42 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz.
I'd suggest that the plastic end tank on the radiator is a good spot to start looking, it could be cracked around the neck to the hose, or the seal between the plastic end tank and aluminium core is failing. If its leaking without being under pressure its time to get it addressed properly. Track down the leak by following the leaking coolant visually, given your description it shouldn't be too hard to pin point.
Riding in style
Old 03-07-2012, 04:41 AM   #3 (permalink)
First of all thanks Brettski, you seem to be helping alot of us less in the know
I will check in the morning, if it is the plastic end tank, dose that mean I need a new radiator? From the possible source of problems are there different ways of dealing with the problem or am I in for a big bill either way?
Thanks
Old 03-07-2012, 12:02 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Get a friend to fill the Rad and lay underneath the front... It does appear to be a "direct" leak as opposed to a Cylinder-Head or Heating issue...
I suspect a coolant hose !! This can lose coolant quickly and run along the base of the Rad... Just adding to Bretts great explanation
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Need Help Coolant Leak ! lonewolf 3-Series (E36) 2 03-07-2009 03:33 PM
Coolant leak svitt 3-Series (E36) 0 10-08-2008 06:09 PM
coolant leak.... yammahamma 3-Series (E21, E30) 18 01-25-2008 10:25 PM
Coolant Leak PhatCat 3-Series (E21, E30) 5 09-19-2006 10:48 AM
coolant leak white 330ci 3-Series (E46, E90) 2 09-08-2004 06:39 PM
